12-16-2013, 08:30 PM   #1
Marketplace Reseller
innivus's Avatar
67ii rolls short 2 frames
I put a few rolls through a 67ii I recently acquired, and each 120 roll only printed 8 photos (there are also only 8 on the negative, though the camera counted up to 10). I've done some research on this and couldn't find much. So I'm left with a few possible options and was wondering if anyone had encountered any of them:
1) The lab missed 2 shots per roll
2) The rolls were miscounted in the camera (they tended to be the last 2 photos taken on each roll, but it was tough to tell)
3) There is an issue with spacing on the film advance mechanism.
I'm assuming it's #3, since 1 and 2 are just a bit too weird. Anybody else encounter this?
12-16-2013, 08:35 PM   #2
LFLee's Avatar
QuoteOriginally posted by innivus Quote
I saw several people reporting this issue as well (online). It appear to be an issue that is fixable.
One of it is here: https://www.pentaxforums.com/forums/48-pentax-645d-medium-format/171505-penta...g-problem.html
12-16-2013, 08:56 PM   #3
innivus's Avatar
Thanks Lee. Mine is doing the exact same thing, so I'm thinking it's off to Arizona for the 67ii...
12-16-2013, 08:57 PM   #4
LFLee's Avatar
No problem, would be great if you can report back if they tell you what is the problem and how much it cost to get fix...
12-17-2013, 03:08 AM   #5
revdocjim's Avatar
How big is the spacing between frames?
And forgive me if this is too obvious but are you advancing the film to the start line before closing the back? Failing to do so will cause the very problem you describe since the first two frames will be shot on backing paper only.
12-17-2013, 05:17 PM   #6
FrankC's Avatar
If I remember correctly when I used to work at a lab we had to unspool the 120/220 film and roll it back up so that the film was in the same state as it was when purchased. That is to say that the first frame is at the front of the line going into the developing machine. If this wasn't done then we'd fog the film and loose an exposure. But I remember it only being an issue with one frame and not two.
12-17-2013, 07:48 PM   #7
innivus's Avatar
QuoteOriginally posted by revdocjim Quote
The spacing actually increases as the roll goes along. It's weird, but very much like the image in this post. And yeah, I'm 99% sure I'm putting the film in correctly, and no worries - I've done enough dumb stuff in my life to warrant the most basic of questions.
12-19-2013, 06:40 AM   #8
revdocjim's Avatar
Oh... that looks wrong! Spacing on my 67ii varies between 3mm and 4mm thru the whole roll.
67ii, 67ii rolls, camera, medium format, photos, roll, rolls
Short film made on Pentax-A 50mm f1.2 metaphiston Video and Pentax HDSLRs 7 03-28-2013 06:57 PM
How to install frames into WG-2 ? lotech Pentax Compact Cameras 2 07-30-2012 09:12 PM
short telephoto lens with bokeh like tomioka 55/1.2 sadchi Pentax SLR Lens Discussion 3 06-28-2012 07:14 PM
For Sale - Sold: REDUCED: Mamiya 645af w/ 80mm 2.8, film back, strap, and some 120/220 rolls. boosted03gti Sold Items 16 11-15-2011 11:32 AM
All times are GMT -7. The time now is 09:46 PM. | See also: NikonForums.com, part of our network of photo forums!
