01-07-2014, 02:44 PM   #16
Silent Street's Avatar
Just out of curiosity, is that threadlock visible in the picture in liquid or solid form?
I would imagine the threadlock is a very light-duty type because of the risk of tool slippage when screwing things together compared to e.g. automotive (engine) use which uses high torque forces, one wouldn't use a beast of a wrench to lock things together on a lens?
01-08-2014, 06:12 AM   #17
Giveaway winner!
MysteryOnion's Avatar
QuoteOriginally posted by Silent Street Quote
That is the solid form... I have yet to need to remove the shroud.
My lens seems stock and yet to be overhauled. I did remove the front element when I first got it to remove a small few dots of fungus.
Depending on diameter of the screw, it seems to stay below 10 in/lb and I've only had one thread locked screw give me trouble until I applied heat. As in autos you would reach for the "BIG RED WRENCH", a 35 watt soldering iron touching the right spot does wonders.
45mm, barrel, camera, front, issue, lens, loose ring, medium format, p67ii, smc 67 45mm, thread
How to fix a loose front lens? kawaist Troubleshooting and Beginner Help 6 10-08-2013 12:25 PM
For Sale - Sold: Pentax 67 600mm f4 lens EXC+ with case+ front cover DanielT74 Sold Items 8 03-05-2012 01:43 AM
Pentax-F 35-70mm lens front barrel is loose violini Pentax SLR Lens Discussion 2 08-08-2011 10:42 PM
SMC Pentax-M f1.4 50mm loose front ring? theperception2008 Pentax SLR Lens Discussion 6 05-04-2011 08:06 PM
SMC M 50mm f1.7 Loose front element fccwpe Troubleshooting and Beginner Help 6 02-02-2011 01:58 PM
All times are GMT -7. The time now is 07:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
