07-21-2014, 08:40 AM   #16
macro
Which apertures are you using your lenses at? In my work with the 645D it pays to keep in mind the old rule of the thumb: " the best performance from any lens you really need to stop it down two stops"
The Zeiss 100mm f/2 macro isn't apochromatic - neither is the D-FA 645 Macro 90mm F2.8 ED AW SR*. The 90mm f/2.8 benefits for having a wider aperture than the FA645 120mm f/4 and has updated optical coatings which means improved resistance to flare and also optical image stabilization - which is not really needed with studio flash bit it is invaluable in the field.
* From many years of working with the Pentax SMCP-FA 645 120mm f/4 I can say that it is very close to being fully apochromatic, it compares well to the Leica APO Summarit-S 120mm f/2.5
I am using f11 for the above aperture.
took another one 2 days ago with f16, 1/125 shutter and iso 800. A120 macro with full set of extension tubes.
tripod for support and flash light used. I am beginning to get used to this set up
marcus
100mm, 100mm macro, 90mm, camera, lens, macro, medium format, range
Pentax FA 100mm 2.8 macro vs Tamron 90mm 2.8 macro el baroda Pentax SLR Lens Discussion 11 06-11-2014 04:44 AM
Wanted - Acquired: Tamron 90mm macro / Sigma 105 ex dg macro / Pentax 100mm macro pentakxian Sold Items 6 05-31-2013 09:58 AM
Vivitar 90mm macro vs. Tamron 90mm f2.5 macro slip Pentax SLR Lens Discussion 3 04-30-2013 08:12 PM
Macro lens(Tamron 90mm+Pentax 100mm)+TC? 123jippo Pentax SLR Lens Discussion 8 07-31-2012 04:28 PM
All times are GMT -7. The time now is 07:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
