The P series is only recommended for down to 28mm on 35mm format, you'll probably see some decent vignetting in your shots.
The angle of view from your 35 would work out to be about 21mm on 35mm format, so the wide angle adapter for the P series should do the trick as it eliminates the vignetting down to 20mm on 35mm format.
If you have other wide angle lenses or ultra wide lenses you may want to consider moving up to the 100mm filter size which is better suited to medium format and digital because of the wider lenses and larger thread mounts. It is a standard format and will give you plenty of options with many brands to choose from and both resin and glass filters.
