06-17-2015, 04:32 AM   #31
Kolor-Pikker's Avatar
I should point out that both mechanical and electrical technologies have a way of breaking "immediately", with a high percentage of failures happening in the first 5~10% of service life. From an engineering standpoint, if the 645Z's shutter fails within around 5000 actuations, that simply means that it was faulty from the start and its failure was inevitable.
Even if you get a "good" shutter, do note that the mean time before failure for mechanical and electrical devices is spread out fairly evenly, meaning that the shutter is as likely to last twice as long as the rated amount as it is to break before that time. 50k or 100k or any other amount is only the "guarantee", not the actual mechanical tolerance of the product. Think about it - how many shutters and for how long have they tested to get that number? and in which conditions? certainly not nearly enough to produce a meaningful, scientific number, compared to the thousands of cameras out in the wild right now.
645d, 645z, angle, backup, bodies, camera, cr kennedy, e-m1, guys, issue, leica, lenses, medium format, pentax, repair, service, shutter, system, times, view, weeks
Abstract Wardrobe Malfunction Kerrowdown Post Your Photos! 10 08-17-2014 03:45 AM
K-01 malfunction ivanvernon Pentax K-01 12 02-03-2014 01:14 PM
K30 Sensor Malfunction K McCall Pentax K-30 & K-50 12 02-04-2013 08:38 AM
External Flash K30 malfunction theoicarry Troubleshooting and Beginner Help 2 01-05-2013 02:00 PM
Help with 645 malfunction branden Pentax Medium Format 5 12-07-2012 02:24 PM
All times are GMT -7. The time now is 08:32 PM. | See also:, part of our network of photo forums!
