09-28-2014, 08:16 AM   #1
adwb's Avatar
645 and 55mm for portraits?
Excuse my ignorance but is the standard 55 mm supplied as the " kit lens" any use for portraits or is really a landscape lens?
for a 3/4 shot how close would you have to get to the subject with this lens and does it distort features at that close distance?
09-28-2014, 08:54 AM   #2
hooverfocus's Avatar
QuoteOriginally posted by adwb Quote
Less than 2 meters away, you'd still have a nearly full-figure portrait. You'd have to be pretty close to get a portrait out of it, it's definitely wide.
The 75mm would already serve you, but any longer dedicated focal length lens would help your cause better.
09-28-2014, 08:56 AM   #3
boriscleto's Avatar
The 35mm equivalent is a 28mm.
09-28-2014, 09:00 AM   #4
It's wider than a classic 'portrait' lens. 85mm on FF seems to be the photographer-consensus portrait lens. 55mm on 645D is about 43mm on FF. 55mm on 645 film is about 35mm on FF.
It will distort in the same manner that a 43mm or 35mm lens will distort. So a bit.
If I wanted to get a portrait lens on the 645D I'd be aiming for a ~100-120mm lens. Some of them are not very expensive.
09-28-2014, 12:10 PM   #5
It sounds like the OP is talking about the 645D/Z if 55mm is the "kit lens". If that's the case, sure, a normal focal length is also fine for doing portraits. You'd have to be more specific if you mean head shots vs 3/4 or full body, etc.
09-28-2014, 12:52 PM   #6
QuoteOriginally posted by boriscleto Quote
No, the APS-C equivalent is ~28mm.
09-28-2014, 01:55 PM   #7
boriscleto's Avatar
QuoteOriginally posted by ElJamoquio Quote
Read the chart wrong. 55mm on crop 645 is equivalent to 43mm on 35mm or 28mm on APS-C. Never post when you aren't fully awake.
09-28-2014, 11:47 PM   #8
adwb's Avatar
Did I not say 3/4 in my original post?
Thank you every one for the answers.
09-29-2014, 02:58 AM   #9
no - it will distort the same as 55mm lens on 135 format - that's the beauty of MF/LF photography, relatively long focal length lenses give you wider angle of view without the drawback of distortion attached to wide angle lenses - I use quite often my 50mm lenses on Mamiya 6 and Hasselblad V for full body portraits even though on 6x6 format angle of view is similar to 28mm lens on 135 format.
09-29-2014, 09:26 AM   #10
I disagree completely. I'm not talking about the minor non-rectilinear distortion, I'm talking about 95% of the distortion, which is the projection to rectilinear. It will distort the amount as a 43 on 135.
10-15-2014, 04:33 AM   #11
Thought I would show a couple of images that may help. The Man and his son was taken with the 55mm and the Portrait with the 150mm Pentax Lense. I do not see any distortion in the 55mm. But, thats me, and My eyes.
The 150 mm lenses was a great surprise, fantastic lense, not too expensive and much to my surprise, small and light, very light. At first I thought I would end up sending it back,,, no way now.
PENTAX 645Z  Photo
PENTAX 645Z  Photo
10-17-2014, 04:54 AM   #12
QuoteOriginally posted by hexx Quote
since 55mm is normal for the 645 d&z , I would think that a 75 or 90mm lens would be best for portraits. one last thing, I never compare my 645 lenses to the 35mm format. I only compare it it the 645 film size since that's what the lens is scaled for. I try thinking the same way as when I compare a lens on a aps-c against a 35mm sensor.
10-17-2014, 12:18 PM   #13
mikeSF's Avatar
oooh i miss Hawai'i. Nice portrait.
10-20-2014, 09:45 AM - 1 Like   #14
Dominia's Avatar
I like to use the 55mm for portraits
645D + 55mm f/2.8
https://www.flickr.com/photos/dominia/sets/72157644528861393/
10-20-2014, 04:42 PM   #15
QuoteOriginally posted by mikeSF Quote
Thank you
camera, medium format, post
For Sale - Sold: 645 body, 55mm, 75mm, 150mm lenses and Adapter K Nachodog Sold Items 20 11-25-2011 08:46 PM
55mm vs. 77mm for portraits on a crop sensor paperbag846 Pentax SLR Lens Discussion 40 03-13-2011 08:29 PM
K5/K7 with K-Adapter/645 and PENTAX-D FA 645 55mm F2.8 = WEATHERPROOF??? Wololo Pentax News and Rumors 9 09-08-2010 05:14 AM
PENTAX Japan exhibits 645D and 55mm f/2.8 lens for 645 Ole Homepage & Official Pentax News 2 05-27-2009 11:32 AM
All times are GMT -7. The time now is 07:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
