Originally posted by goodnight Hope you have fun and it all goes well!
Well, few discoveries were made during the process.
First up, I did manage to get the pressure plate off. Quite a feat given the (non-)tools I had.
And this is what the rear of the pressure plate looked like. Compare to what a normal plate should be like
here (from the aforementioned
astro topic).
Taking that plastic thing off was hard. Suddenly, I'll retract what I said about the sloppy job.
This step was necessary as I wanted to restore the 120 functionality of the pressure plate. With the mod in place, the added thickness meant it could not be moved back and forth from 120 to 220 (and it was stuck on 220).
I decided to recycle the black thingy in order to close up any holes left by the previous mod. I glued it in place and further sealed it with some gaffer tape. Unfortunately the film type tab that is visible
here was no longer in place so I'll have to do without.
Finally, I mounted back the pressure plate. 120 can now be selected normally.
Last thing left to do is finding some leatherette to fix the butchered one that's currently on. I won't be able to fix the film type window thingy (it won't show any number) but I guess I can live with that.
Until the day I stumble upon a back from a parts camera...
