10-16-2014, 06:15 AM   #16
From where I can download the software
10-16-2014, 08:26 AM   #17
QuoteOriginally posted by rolleiaf Quote
You can't, you have to buy it 179 from the Ricoh online store.
10-17-2014, 03:52 AM   #18
Lightroom works for both RAW PEF and RAW DNG if you setup a watched folder and enable auto import. Works well, but the downside is it takes longer 8 Seconds. But it's workable, not really that long. If i use the live view on the Image Transfer window to set the shot up then that will already save me time. Thinking now that I will use lightroom instead of the capture option because at least then I know that the colours/ wb are true.
10-24-2014, 10:23 PM   #19
I just received the camera today, and the image transmit software was on the CD included with the camera....
10-25-2014, 02:41 AM   #20
QuoteOriginally posted by Victor Wolansky Quote
That's very sensible. +1 to Ricoh for doing so.
10-25-2014, 10:23 PM   #21
Although it might be different from country to country, I know a guy in Germany who got no CD but a jacket :-) with the camera
10-29-2014, 05:50 AM   #22
Although I have not timed it with a chronometer, I can say that in my system is less than 5 seconds from click to show up in LR, since I'm using a system to focus stacking that takes a shot every 5 seconds and the shots show up in the LR library just before the next shot is taken. One thing to check is that the folder where they land is on the same drive as the LR library is so they are just moved, which is instantaneous, instead of copied that takes a few seconds.
12-27-2014, 06:03 PM   #23
No IT2 in box
As far as I can tell IT2 is NOT included with the 645Z. I purchased mine from B&H in early December 2014
12-30-2014, 07:35 AM   #24
Did not come with mine either and I am in Canada
01-27-2015, 09:10 AM   #25
Very disappointed with the software. Even more disappointed that Ricoh has yet to respond.
REVIEW: Ricoh IMAGE Transmitter 2 Software - Mark Kitaoka PhotographsMark Kitaoka Photographs
02-01-2015, 05:23 PM   #26
I just ordered it from B&H, but I forgot the cable
02-02-2015, 07:59 AM   #27
You can buy one cheap at any computer store. Just make sure you get the right connector for the camera end. Nothing special about it. You in particular do not need an expensive USB3 cable.
- N.
02-05-2015, 06:10 PM   #28
Hey Nick how are you transferring it into LR5 and also is there a way to get full screen?
02-06-2015, 08:23 AM   #29
QuoteOriginally posted by mrclark321 Quote
You transfer via IT2. Set the import import file, then in LR5 chose that same file as the watched folder in auto import. FILE --> AUTO IMPORT --> SETTINGS
Make sure the folder is EMPTY! before you start or it won't work. "ENABLE" auto import under the same drop-down menu, and start shooting. LR imports every file that comes into the watched folder.
IT2 does not work full screen - it is really just a conduit for the data. LR can and with a 2nd monitor you can have the live previews up on it.
02-01-2016, 04:56 PM   #30
Intersting. I never thought Capture One would make anything work with Pentax medium format cameras. They regard Pentax as competition to Phase One Cameras (?) Too bad for me, 'cause I don't like Lightroom at all :-)
Regards
Jens
645d, 645z, camera, image, image transmitter, medium format, transmitter
Image Transmitter 2 to be released September 26 JPT Pentax News and Rumors 24 11-12-2014 06:10 PM
Who is using what? K5 Guy Digital Processing, Software, and Printing 12 11-15-2013 03:34 PM
Soft image when using M-50mm f/2 on K-01 mythguy9 Pentax K-01 21 02-21-2013 12:03 PM
Who here is still using the K20D? rfortson Pentax DSLR Discussion 4 05-25-2012 06:42 AM
Hasselblad (film) anyone? Who is using them? jpzk Non-Pentax Cameras: Canon, Nikon, etc. 20 10-24-2010 04:52 PM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
