10-14-2014, 09:36 AM   #1
Helicoidal Extension Tube
Hi all,
I'm new to Pentax 645 world and I have a question
surely a stupid one :-)
I have the 645Z and the new 55mm that comes with it
I bought the Helicoidal Extension Tube on Ebay ,but there is no coupling with the aperture !
is it possible to change the aperture in this lens manually ? or maybe it isn't compatible with the Helicoidal Extension Tube ??
if so, what lenses are ok to use with it ?
thanks
10-14-2014, 11:19 AM   #2
I guess you need a lens with aperture ring do control it manually.
10-14-2014, 12:06 PM   #3
Simple answer. NO. As there is no mechanical aperture coupling, you can not control the aperture of the D FA 55mm lens. You will need any FA or A lens which has an aperture ring to get aperture control, and then you will need to use it in stopped down metering mode.
Regards
Chris
10-14-2014, 01:52 PM   #4
Thank you seventhdr, that's what I thought !
Cheers
Laurent
645d, 645z, aperture, camera, extension, medium format, tube
Macro Extension tube woes Undot Photographic Technique 12 09-17-2014 02:00 AM
TC to Extension Tube london.paul1 Pentax Camera and Field Accessories 4 05-20-2014 05:23 AM
Extension tube PK mount pixie Pentax Camera and Field Accessories 14 11-07-2013 07:17 AM
extension tube mikol Welcomes and Introductions 8 07-16-2013 12:41 PM
Extension Tube K 100 Cloapex Pentax DSLR Discussion 8 03-11-2013 12:13 PM
All times are GMT -7. The time now is 06:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
