Originally posted by Digitalis If anyone did, they would have a tough time recouping the development costs.
The Leica visioflex system was designed for 35X24mm frame size, the lenses won't be able to produce an imaging circle big enough to adequately cover a 33X44mm sensor. Also visioflex lenses are very old and tend to be rather hard to find - especially the 12.5cm f/2.5 which is a rare lens. You would be much better off getting a Leica S2 system with current state of the art designed for medium format lenses, rather than digging through the past for sub-par solutions.
The system is called Visoflex and not "visioflex". Many of the lenses designed for that system are well known to cover medium format, including the 65mm, the Hektor, and the 200mm. In fact, these lenses cover the full 6x6 film format and even 6x7
https://www.flickr.com/photos/esquisses/4522415966/.
Especially the Hektor is easily adapted using the readily available M39 P645 adapters. The original poster just bought a P645Z - chances that he/she will swap systems are slim. The 12.5cm Hektor has wonderful bokeh and is ideally suited for portraits. It gets very sharp when stopped down and even at 2.5 it is very usable for portraits on the 645D or 645Z (I own both). In fact, chances are, that because of the sensor and image processing, the P645Z with the Hektor may be preferable to the Leica, even though their new 100 is likely to render clinically sharp images at full aperture. But that depends on the type of application you are going to use the lens for. If it was me, I'd rather use the Hektor with the P645Z, especially if I already own one. I can assure you, there is no light fall-off nor image degradation toward the edge of the frame, especially with the small 44x33 sensor. As I said, those lenses easily cover 6x7.
---------- Post added 11-01-14 at 10:45 AM ----------
I guess the other questions is whether you own any of these.
---------- Post added 11-01-14 at 10:48 AM ----------
... and I should also add that some of these Visoflex lenses are Mandler designs that were calculated and manufactured in the Midland Ontario plant. Some of the best lenses ever made. I used to own both a Midland and a Wetzlar copy, and I sold the Wetzlar copy. Rumors have it that all were manufactured at Leitz Midland, the Wetzlar ones were just relabeled. Anyway, these are marvelous lenses by all means.
