03-31-2015, 10:21 PM   #16
Thomasbrowphoto's Avatar
Woah really good timing. I have had my Da25mm send off for repair for loose Barrel and AF not working. Hopefully will be getting mine back tomorrow. PC board replaced, any insights as to what was happening?
04-01-2015, 04:02 AM   #17
Digitalis's Avatar
QuoteOriginally posted by Thomasbrowphoto Quote
If I had to guess: the damaged board was reporting incorrect aperture values to the camera, some old sigma lenses have this issue. The symptoms look similar.
04-07-2015, 04:38 AM   #18
This might be a bit off topic, but I just wondered if any of you have played with different "Program Line" settings. On the 25 I try to use maximum DOF. and matrix metering. Any comment?
04-07-2015, 08:48 AM   #19
mikeSF's Avatar
QuoteOriginally posted by algrove Quote
sorry, i don't use any of those things. I am M mode and centre-weighted & spot metering primarily. Are you specifically asking what the camera algorithm is for max DOF?
04-21-2015, 04:34 PM   #20
QuoteOriginally posted by mikeSF Quote
Yes, since on the 645Z they are icons, but the manual describes them. I assumed most use them instead of the default setting.
25mm, 25mm 645 lens, 25mm da645 exposure, 25mm f4 da, 645d, 645z, aperture, camera, da645, exposure, exposure variations, f4, lens test, medium format, range, row, test
K-3 exposure issues Romeo Bravo Troubleshooting and Beginner Help 3 07-27-2014 08:19 AM
Bounce flash over exposure issues solved in latest firmwares? Lage Pentax DSLR Discussion 11 10-22-2013 08:51 AM
Hello! I have a K-30 with exposure issues elijah Troubleshooting and Beginner Help 9 08-14-2013 07:07 AM
Fix the flash exposure issues Pentax! Lage Pentax DSLR Discussion 45 11-25-2012 08:02 AM
Où trouver l'objectif DA645 25MM F/4 ? vincen General Talk 3 06-10-2012 07:53 AM
All times are GMT -7. The time now is 08:21 AM. | See also: NikonForums.com, part of our network of photo forums!
