11-13-2014, 02:33 AM   #1
25mm DA645 exposure issues?
Just did 2 exposure tests on a brand new 25mm DA645.
1) Ran through full aperture range, dropping -1 shutterspeed to +1 aperture increase. Difference between f4 and f32 is several stops?! (top row)
2) surprised, I then ran same through on Av, Increasing aperture and leaving camera to choose shutter (bottom row).
Not sure what to make of this yet, but test 2 is indicating the lens is not f4, but more like f4.5. And the non-linear relationship in test 1 concerns me - either the aperture values are way out, or the aperture itself is sticky?
Has anyone else struck this? What do you think? (FYI, I repeated with a 35mm 'A' and a 55mm D-FA and got very little variation across the aperture range).
Many thanks, Rob
11-13-2014, 04:18 AM   #2
Digitalis's Avatar
before rushing to judgement are you using the filters included with the lens?
11-13-2014, 06:33 AM   #3
I think vignetting might be to blame. It's fairly pronounced wide-open.
11-13-2014, 10:13 AM   #4
It's as if your metering system is reading your shutter speed but your diaphragm settings are not being read. An electrical connection?
11-13-2014, 02:01 PM   #5
Hi Adam. It's way too pronounced for that and it's right across the frame. Haven't measured but it could be 2-3 stops off the centreline?
Hi Digitalis. Yes, I had the factory clear/uv in. Ps, our digitalis is just coming into flower here. Shame it's a significant weed as it's a beautiful plant.
Rob
11-13-2014, 03:53 PM   #6
Thomasbrowphoto's Avatar
This is very interesting. I had similar issues when I first got the DA25mm lens on my 645Z. But my encounter was a lot worse... and it turned out to be the aperture leaver getting jammed in the camera body. Not sure if its the same problem. I now have the same lens but on a new replacement body no problems so far... Just keep an eye on it. My differences were about 5-6 stops and inconsistent.
11-13-2014, 04:10 PM   #7
Thanks mate, that's interesting to know. Did it just happen with the 25mm or all lenses? I'm assuming all lenses if it was the body? I didn't see it with the 55DFA. Rob
11-13-2014, 06:47 PM   #8
I don't have this issue with my 25 and the Z...
11-14-2014, 04:04 PM   #9
For what it's worth, I too have not seen anything like this with my 645D / 645Z and the DA 25mm. Some of those test results might be attributable to small metering variances. But the manual sequence in particular looks like the whole series was not exposing properly, after the first exposure. Possibly the aperture indeed is not getting stopped down properly beyond f/4. This would be easy enough to test using an extreme near/far composition focused on either the foreground or background, and shot at f/4 and then again at f/32. It could be double-checked in Live View with the DOF-preview button as well.
What version of firmware is on the 645Z? There were a number of bugs in the first firmware that shipped with the camera, that were fixed in the update put out a few weeks ago. If your Z isn't running the newest firmware, I highly recommend updating it right away. I found a number of the initial firmware bugs but most were merely annoyances that could be worked around, but still... Also, do you have any camera settings / custom functions enabled that could be monkeying with exposure? I normally disable all of these automagic functions, and shoot in full manual mode most of the time. As I said, I haven't seen a series like your series #1 come out of my D or Z.
When you repeated the test with the D-FA 55mm this should have indicated if there was a problem with the camera body (e.g. an aperture lever failure like Thomas experienced). The 55mm has a similar 100% camera-controlled aperture mechanism, lacking any physical aperture ring on the lens. Since the 55mm lens worked, all other things being equal, I'm suspecting a problem with your DA 25mm...
11-14-2014, 06:15 PM   #10
Hi Royce
Thanks for taking the time. Lots to think about. And yes, it is the latest firmware I've updated to.
Agree regarding the 55mm. It definitely seems like a lens thing.
I accept that there could be some exposure differences attributable to the Z 'monkeying' around with the exposure, and I also agree that vignetting has a role, but it's looking like a 2-3 stop deviation in the centre.
I'll try to find some time to do more tests in the next couple of days.
Thanks, Rob
11-14-2014, 07:06 PM   #11
Yes, from the way your sample set looks it's a deviation of at least 2 - 3 stops and I can't think of a way to consider it "normal" unless the ambient light itself really was changing to that degree. Thinking about other things like firmware, automagic exposure settings and whatever is just a way to rule out the obvious. But my gut says there's something with your lens...
11-17-2014, 03:30 PM   #12
QuoteOriginally posted by rob8888 Quote
Hi sorry on the late reply! Initially it was only with the DA25mm but then happened with any lens I tried to use. Could be a completely different issue though.
12-17-2014, 10:12 PM   #13
QuoteOriginally posted by Thomasbrowphoto Quote
Interesting. Tried out my DA25mm lens on another new 645z and it did it on that camera also (has done it on all firmware versions too). About a 3 stop difference from wide open to closed aperture on the same Ev value through the range and it's only taken about 50 frames to date. Didn't happen with the 28-45. Hence it's gone back for checking.
Rob
03-31-2015, 10:12 PM   #14
Rob
How did you go with the lens getting sent off mate, was it corrected or replaced? I hope it was a good outcome.
03-31-2015, 10:14 PM   #15
Hi there. Good timing. Just arrived back from Japan yesterday. PC board replaced. Haven't tried it yet.
25mm, 25mm 645 lens, 25mm da645 exposure, 25mm f4 da, 645d, 645z, aperture, camera, da645, exposure, exposure variations, f4, lens test, medium format, range, row, test
K-3 exposure issues Romeo Bravo Troubleshooting and Beginner Help 3 07-27-2014 08:19 AM
Bounce flash over exposure issues solved in latest firmwares? Lage Pentax DSLR Discussion 11 10-22-2013 08:51 AM
Hello! I have a K-30 with exposure issues elijah Troubleshooting and Beginner Help 9 08-14-2013 07:07 AM
Fix the flash exposure issues Pentax! Lage Pentax DSLR Discussion 45 11-25-2012 08:02 AM
Où trouver l'objectif DA645 25MM F/4 ? vincen General Talk 3 06-10-2012 07:53 AM
All times are GMT -7. The time now is 04:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
