11-22-2014, 02:38 PM   #1
645Z lens choice
Hi All - Id appreciate your thoughts on lens choice for my new 645Z primarily for landscape and portraiture. I've also contacted one or two 645Z users directly , so apologies if I'm duplicating my question to anyone.
I've just tried my 45mm and 165mmLS 67 lenses on my new 645Z with the Photodiox adapter , with mixed results.....the 45mm landscape shots were rather 'mushy' and the 165mm hit and miss (OK on higher contrast images , but again 'soft' on landscapes) ......I also tried a used 120mmF4 FA macro with some success, but again not as good as I had been led to believe from reading other online reviews (eg I read "tack sharp out of the camera...", but my RAW files look a soft and a tad 'milky')
I guess my question is do I have to 'bite the bullet' and invest in the new DFA lenses (55mm , 28-45mm and 90mm macro) to get the best out of the new sensor?
Regards to all , Ian ( in Canada and UK)
11-22-2014, 04:41 PM   #2
You found the 120 not sharp? Either you have a bad copy or you doing something wrong. I use it for jewelry and the thing IS sharp. The 90 is sharper, but you can't get 1:1 macro. The DFA lenses are better for sure. But the 120 is not a bad lens. Not at all. The 25, I got it and returned it in favor of the28-45 which is much better.
11-23-2014, 11:48 AM   #3
Thanks
Hi Victor - many thanks...I was not using the 120mm macro for close-up , but for architecture and landscape....an architecture pic (church interior) looked good after Lightroom processing but seemed to need a lot of 'Clarity/Contrast' processing to get micro-contrast I expected into the picture.....perhaps my expectations were too high as I have been spoiled by the detail from my Nikon D800 images (which are already at 36MP) and was perhaps expecting the same jump in image quality as when I upgraded from my previous 20MP Nikon..? Anyhow I will try the 120mm again to check if I am making any fundamental errors , as I must admit I am not yet accustomed to the shallower depth of field from the 645...
Noted what you say about the newest DFA lenses.
I did look at your website , and was very impressed by the jewellery shots , and the 'behind-the-scenes' set-ups you showed...obviously lots of 'tricks of the trade' , experience, and patience required to get the 'look' your clients want!
Thanks again , Ian
11-23-2014, 11:55 AM   #4
mikeSF's Avatar
Ian,
post up some shots if you like and we can help you figure out whats going on.
I find my A120Macro to be one of my best landscape lenses - there is no problem at all using it on the 645D. Even with an increase in resolution from the Z, i do not believe this and several of the older A- lenses, for example, will leave you wanting.
11-23-2014, 10:18 PM   #5
QuoteOriginally posted by BostonUKshooter Quote
Thanks again , Ian
Thanks!
11-24-2014, 01:25 AM   #6
Hi Ian
As I said in my email to you the lenses (a, da) are all excellent...notwithstanding any faulty ones. But very good technique is required: MLU, timers and rigid tripod etc. I switch of auto focus for landscape work and use the excellent live view.
Yes shallow depth of field is an issue and symptomatic of a larger sensor. Focus stacking is helpful, depending on subject matter.
I find that in my work I apply less sharpening than to dslr files. In fact I apply little or no output sharpening for printing up to 30inches. The sensor is that good. I depend on the texture of the paper to add perceived sharpness.
My Facebook page has some of my latest 645z images: www.fb.com/guyaubertinphotography
Feel free to ask away. I have been using the 645z system for several months and find it amazing.
Guy
11-25-2014, 02:40 AM   #7
Lens choice
Thanks again Guy - tried the 165mmLS again yesterday , and got some good results, although the 45mm still looks a bit soft...
Will try out the new 90mm macro this week , to see if its as good as the reviews....
I like the animal/people images on your website....
Thanks again , Rgds, Ian
45mm, 645d, 645z, camera, choice, landscape, lens, lenses, macro, medium format, portrait, question
old lens for 645z adwb Pentax Medium Format 13 10-24-2014 06:43 PM
Kit lens choice..?? 2put Troubleshooting and Beginner Help 10 11-16-2013 04:18 PM
Lens Choice theWags Pentax SLR Lens Discussion 5 11-10-2013 01:06 AM
Lens choice questions wally1 Pentax SLR Lens Discussion 7 08-05-2013 02:59 PM
Lens choice question. Gord K. Troubleshooting and Beginner Help 7 04-20-2013 08:56 AM
All times are GMT -7. The time now is 12:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
