11-24-2014, 03:03 PM   #1
Lenses Compatible with 645z
I know of the backwards-compatible Pentax lenses, but are there any will work with and an adapter and retain full field of view? I could be wrong but I think normal lenses with adapters won't work, e.g. a Canon 85 f1.2 won't get full field of view, right?
11-24-2014, 03:36 PM   #2
boriscleto's Avatar
https://www.pentaxforums.com/forums/48-pentax-medium-format/145963-pentax-med...a-adapter.html
11-24-2014, 04:03 PM   #3
QuoteOriginally posted by chomsky Quote
Any Pentax 645 lens will work, or you can use 67 lenses in Av or M mode with an adapter.
11-24-2014, 04:59 PM   #4
What you're describing, using a 35mm system lens on a medium format camera, isn't practical. If a physical adapter was available or custom machined you wouldn't be able to focus to infinity--there is more distance between the 645 mount and sensor than there is with a 35mm system.
Going th other way works--a quick search shows that using Hasselblad V lenses on the 645d/z is possible, and of course Pentax 67 lenses as well.
11-24-2014, 05:43 PM   #5
Digitalis's Avatar
The canon EF 85mm f/1.2L can't cover the format properly, also the registration distance of the lens make it impossible to use on the 645 system.
11-27-2014, 09:11 AM   #6
Using other medium format lenses with an adapter would work though?
11-27-2014, 09:17 AM   #7
Digitalis's Avatar
It is possible to do this - however the adapter may cause issues as the mount may not be perfectly parallel or the adapter may have light leaks.
12-04-2014, 05:18 AM   #8
stick with pentax 645 and 6x7 lenses with adapter and you'll be in hog heaven.
645d, 645z, camera, field, lenses, medium format, view
Just ordered a 645Z and I need help with lenses rodagon Pentax Medium Format 15 09-01-2015 02:10 AM
Confused by Pentax Lenses - Which ones are compatible with K-5? theraven871 Pentax SLR Lens Discussion 4 03-01-2014 04:46 PM
Looking for digital Pentax body compatible with zX-M SLR film lenses? Midnit_kos86 Troubleshooting and Beginner Help 14 02-20-2014 10:04 AM
old lenses compatible with the K-X chandra.kant Pentax DSLR Discussion 14 07-12-2013 06:22 AM
Are these lenses compatible with K100D Super? Morbo Pentax SLR Lens Discussion 6 11-13-2008 05:56 PM
All times are GMT -7. The time now is 11:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
