12-23-2014, 11:42 AM   #1
HELP Choosing Trigger For 645D
I have the 645D and want to shoot night shots on a tripod and Have No Camera shake. I know there is a wireless trigger and a Push trigger. I want to have the mirror go up and Shutter release. I will be using AF and NOT manual focus. Can you tell me Pro and Cons aside from the price. Thank you
Then I wish to buy one
12-25-2014, 09:00 PM - 1 Like   #2
mikeSF's Avatar
wireless trigger cons include: so small, gets lost easy. Camera must see the beam to work, limits angle of use.
I use a cheapish $30 Chinese made programmable intervalometer which does the job well. When triggering manually, push once to raise mirror and second time to open shutter. slider to lock in open position.
12-26-2014, 03:24 AM   #3
QuoteOriginally posted by mikeSF Quote
Agree and use a similar unit,
12-26-2014, 05:25 AM   #4
Kolor-Pikker's Avatar
I have had an SMDV RFN3 for my Canon for many years and it works fine, of course I got the same kind for the 645. Vello makes a similar thing called FreeWave, but it seems to be more expensive.
05-01-2015, 04:44 PM   #5
Good info - where can I get one, and specifically what is the model info, etc?
Thanks
05-01-2015, 08:02 PM   #6
mikeSF's Avatar
there are several versions of the same one, under various names. try dealextreme.
05-01-2015, 09:11 PM   #7
I'm not finding anything via internet search.
This unit is new to me. I have a 645z on order and would like to have a remote shutter controller. Search yields programmable intervalometers for canon and nikon, but I don't know the compatibility for the Pentax. Also, I do not find dealextreme.
I'd appreciate a link to a unit that will work for this camera.
Thanks again.
05-01-2015, 11:08 PM   #8
mikeSF's Avatar
i'm ordering a replacement for the one i dunked in the ocean. here you go:
0.9" LCD Wired Remote Shutter Release for Canon/Pentax/Samsung (1 x CR2032) - Free Shipping - DealExtreme
here's another:
http://www.amazon.com/Neewer-Shutter-Release-Hasselblad-PowerShot/dp/B003Q9X...release+pentax
what's peculiar about these is there is not OFF button, so i would reverse one battery to turn it off. eventually my battery door broke and i had a thick rubber band holding the batteries in place. just an fyi
05-02-2015, 12:17 AM   #9
I use the Pentax waterproof IR remote on a lanyard around my neck for tripod work.
Works great. AF not required as you do that when composing using the camera and the AF button anyway.
05-02-2015, 04:30 PM   #10
Thanks for the info! I've got one on order.
05-02-2015, 07:13 PM - 1 Like   #11
FrankC's Avatar
I went with a $20 Vivitar wired trigger. I skipped the intervalometer versions since that feature is in body, and I've yet to use it on my 3-year-old body anyway.
Be prepared to have to modify the wired remotes if you buy a non-Pentax version. The generic versions FOR Pentax all have a plug that's too big to fit into the hole in the 645D. I had to use a bench grinder to reduce the outside diameter of the head of the plug to get it to fit inside the hole. That wasn't a problem as there's plenty of plastic around the plug so I didn't have to worry about exposed wires.
645d, 645z, camera, medium format
IR trigger for 645D or 645Z elsdad Flashes, Lighting, and Studio 8 07-12-2014 06:21 PM
Help with Choosing a Tele for Pentax G.E.Zekai Pentax SLR Lens Discussion 16 07-05-2014 08:14 PM
Help choosing 2nd lens for K-5 Janis Pentax K-5 5 05-10-2011 03:47 PM
Help choosing a system for someone else lavascript Troubleshooting and Beginner Help 20 01-23-2011 02:07 PM
Need help choosing 3 for class tomorrow. LeDave General Talk 7 09-03-2009 10:20 AM
All times are GMT -7. The time now is 10:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
