12-25-2014, 05:32 PM   #1
sunshine7913
Guest
Pentax 67 focusing...
I really hate the focusing screen in Pentax 67 so much. It doesn't have split focusing screen. Because of this, I can't see that the object is in focus or not. God damn it. Also, the focusing screen is really darker than other film camera that I used before. How come this film camera does not have any alternative solution for focusing at all? How am I going to use with this kind of focus screen?
12-25-2014, 06:24 PM   #2
arnold's Avatar
QuoteOriginally posted by sunshine7913 Quote
The easiest way is to just set the estimated distance on the lens. I did this for years on a viewfinder camera with good results. Quick and easy.
12-25-2014, 06:27 PM   #3
Hmm. Check your diopter adjustment - I had a similar disappointment with my first 645 that was caused by a way off diopter setting.
It's strange to hear you say that it's the darkest you've used. What lens are you using, and at what aperture?
I've only used a few lenses on the 67 (45, 75, 105), but I've never seen anything I'd consider dark (Much brighter than my 645), and I found it pretty easy to get critical focus.
What prism are you using?
12-25-2014, 07:09 PM   #4
sunshine7913
Guest
QuoteOriginally posted by robthebloke Quote
TTL meter prism. 105mm f2.4
12-25-2014, 08:03 PM   #5
That is strange. The 67 + 105 + ttl is a really bright combo (and dialling in the focus should be a diddle due to the long focus throw of the 105 - it's one of the best combos I've ever tried).
Make sure the diopter is set correctly, make sure the lens is set to 2.4, and give it a whirl outside (medium format cameras aren't that great in dimly lit rooms). If you have a tripod that can take the weight, then try using that as well - the 67 isn't the easiest layout for hand holding I've experienced!
If after all that the focus is still a pain, unless anyone else has a better suggestion, possibly send it for a CLA.
12-26-2014, 05:42 AM   #6
drougge's Avatar
The most likely explanation I can think of is that you have different focusing screens. As far as I know Pentax never changed it during the same model name, but that doesn't mean a previous owner couldn't have. There are after market screens that are supposed to be much brighter than the original. Probably also ones with a split prism.
12-26-2014, 02:21 PM   #7
You probably have a matte screen. There were split image screens made for this cameras and that sounds like what you need.
12-26-2014, 05:04 PM   #8
gofour3's Avatar
I’m assuming you have your 67 105/2.4 switch set to “AUTO” and not on “MANUAL” with the aperture set to f/22?
Phil.
12-26-2014, 10:24 PM   #9
sunshine7913
Guest
QuoteOriginally posted by drougge Quote
Where can I find the split focusing screen? Mine, matte screen, is too dark and hard to focus the object...
12-26-2014, 11:44 PM   #10
gofour3's Avatar
You are unlikely to find an original Pentax one, so try the Beattie ones. (Not sure if they are user changeable) If you had a P67II then you have more options and can change the screens yourself.
http://www.bhphotovideo.com/c/search?atclk=Brand_Beattie&sts=ma&N=4291592381&Ntt=Pentax++screen
Phil.
12-27-2014, 12:06 PM   #11
I had a hard time focusing my 6x7 TTL, and finally realized the (used) finder had a diopter lens inserted in the eyepiece. Once I removed it I found it easy to focus. However, I've been focusing on ground glass by judging the sharpness since about 1960. I prefer plain ground glass to any split image or microprism screen. Practice focusing enough and it becomes easier and "automatic."
12-27-2014, 12:53 PM   #12
sunshine7913
Guest
QuoteOriginally posted by gofour3 Quote
Pentax screen | B&H Photo Video
Phil.
WOW. Those are TOO expensive to purchase only one split screen.
645d, 645z, camera, film, focus, medium format, pentax, screen
For Sale - Sold: PENTAX 67 6x7 Waist Level Finder - Folding Focusing Hood price reduction vjacesslav Sold Items 1 03-11-2014 09:02 AM
Focusing screen Pentax 67 and Pentax 67II Photodana Pentax Medium Format 2 01-22-2012 06:05 PM
All times are GMT -7. The time now is 06:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
