Hi all,
this is probably a stupid question... both 67 and 645 have like a 12 secs delay timer in body that is useful, when I want to get into the frame myself... (not always a good idea, but sometime the wife insist...), is there a tool to make this a longer delay? I often need to run to or climb to get into the spot and 12 secs doesn't seem enough (and often I need time to catch my breath after running over...
A long cable release + in camera 12 secs might helps a bit, but the cable might get into frame... and I guess there must be something out there?
I googled and find some mechanical tool to hold the shutter to certain amount of time for bulb mode shooting, but nothing for delay shutter. Maybe I use the wrong search term? any help is appreciated!
Thanks!
