02-16-2015, 02:27 PM   #1
Chris Giles's Avatar
120mm Macro Focus Limit - HOW!
Hi folks, I can't seem to find a user manual for the 645 FA 120mm Macro.
I googled it, no luck. It was really just so I could understand the focus range lock feature. I've no idea how to use it.
If anyone knows, please let me know
02-16-2015, 02:40 PM   #2
If it works like every other macro with a range limiter, it simply means that somewhere there is a threshold point on the focus ring where you are in "macro range" and the lock will keep you on EITHER side of that threshold depending on when you enable it. So if it is unlocked, you get the full range. If you set the focus to macro and engage the lock, it will keep you in the macro range. If you are in the normal->infinity range, it will keep you out of the macro range. Just a helper so it isn't hunting around in macro while you are trying to shoot a bird in a tree, or vice-versa when you are trying to shoot a bug 6 inches away it won't be trying to focus out at 30ft...
02-16-2015, 02:43 PM   #3
Flick the switch near close or near infinity and it will limit the focus throw from infinity to ~ 4m or from ~4m to closest focus. Mostly usable at infinity to 4m since at macro you usually focus manually
---------- Post added 02-16-15 at 10:46 PM ----------
what he said because he was faster than me, but I am in bed typing on a tablet
02-17-2015, 06:35 AM   #4
Awesome help, thanks all
120mm, 120mm macro focus, 645d, 645z, camera, focus, infinity, lock, macro, macro focus limit, medium format, range, threshold
how to focus perfectly with manual focus lens? ghiaauto Pentax SLR Lens Discussion 17 09-30-2014 02:37 AM
Macro K-5 + Mamiya 645 120mm f/4 macro igor Post Your Photos! 4 09-13-2013 01:53 PM
Pentax 67 120mm soft focus lens karlfoto Pentax Medium Format 13 12-29-2011 05:16 PM
All times are GMT -7. The time now is 06:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
