02-24-2015, 05:30 PM   #1
35mm 645 A Mold? Should I refund?
I just received a used 35mm A I ordered on ebay from Japan. What seemed to be like a nice catch turned out to have a spot under close inspection.
I bought it for $499 without taxes and duty which mounted up to an additional 120 Euros.
What do you guys think? I contaced the seller and he's offerend a $40 rebate or refund. Appended are some pictures. What should I do?
02-25-2015, 05:56 AM   #2
Don't agree to it! Lens sellers from Japan are notorious for doing this. Contact Paypal and demand a full refund.
02-25-2015, 02:05 PM   #3
QuoteOriginally posted by dcshooter Quote
That's an odd-looking spot for fungus/mold and might be a some other type of debris. Which element is it on? It might be pretty easy to access and clean. A shop will likely charge you at minimum 50, so I'd ask for a refund of at least that much, but if you know anything about lens disassembly, you can probably do it yourself.
It is odd-looking but seems to have some fungi structure to it. I've absolutely no experience with fungus on lenses or mold. The pictures above are from looking through the rear. I've disassembled lenses only up to the first lens element from the back to replace bayonets (Leica 100mm Macro conversion to Canon) or modify the metal around the rear element to get mirror clearance (Minolta Rokkor on Canon FF).
So I thought I could give it a go. The metal ring around the outter rear lens unscrewed easily, so did the smaller ring holding the lens element. After removing that one, I hoped that I would find the annoying spot on the second element, but it turned out to be clean. I didn't know how to go from there, otherwise I would do it. Too bad I didn't make pictures, but I could redo the disassembly and post pics. If you or somebody else could give me advice for the next step I would be grateful!
---------- Post added 02-25-15 at 10:18 PM ----------
QuoteOriginally posted by wrkingclasshero Quote
I would, but the refund would only cover the $499 I paid for the lens. The 120 EUR I paid for German import sales taxes and duty would be lost.
The only way around this is if the seller had another lens he could send as a replacement unit. I totally forgot about this...guess I will ask for a 50 Euro refund, see how that goes and try to clean it myself or to get it cleaned in a shop.
35mm, 645d, 645z, camera, canon, element, lens, lenses, medium format, metal, post, refund, spot
Uh oh! Another should I stay or should I go thread Kameko Pentax DSLR Discussion 35 01-29-2015 02:51 PM
Should I ask a partial refund for this Pentax-A 28/2? malenisjaj Pentax SLR Lens Discussion 27 03-19-2014 12:32 AM
Should I keep my 35mm 2.4? scunning14 Pentax SLR Lens Discussion 9 10-30-2013 09:42 AM
Should I get an extra 120 insert for 645? LightMeter Pentax Medium Format 15 01-21-2012 12:43 PM
How should I inspect a used 645?? troyz Pentax Medium Format 4 01-29-2009 07:54 AM
All times are GMT -7. The time now is 02:52 PM. | See also:, part of our network of photo forums!
