03-04-2015, 10:57 PM   #1
Pentax 67 TTL light metering prism is not working
It worked before. Well, I had to press the lens release button in order to activate the metering in the prism but from yesterday, it started to not working. idk why it happens. Any idea why is this happen to my camera?
03-05-2015, 12:01 AM   #2
Take lens off. Remove prism. Put prism back on. Put lens back on. Hopefully it works. It is possible that the prism came loose and when it was pushed back on the tab on the coupling chain no longer moved the feeler on the prism. If the chain got damaged you will have to stop down meter since the part is no longer available. When the prism is removed also check the power contacts and make sure thy are clean.
03-06-2015, 08:27 AM   #3
gofour3's Avatar
Try moving the lenses AUTO/MAN lever to MAN and see if the meter works. My TTL meter only works this way.
Note you should also look into getting a good hand held light meter, it will make your life easier!
645d, 645z, camera, light metering prism, medium format, pentax 67 ttl, prism, ttl light
Pentax 67 TTL prism light meter! sunshine7913 Pentax Medium Format 5 01-30-2015 02:10 PM
For Sale - Sold: Pentax 67, TTL Prism and 55mm f3.5 lens durr3 Sold Items 2 01-08-2015 02:44 PM
TTL metering in K1000 not working through Vivitar 24/2.8? pentaxk1000denver Pentax SLR Lens Discussion 5 12-12-2011 04:33 PM
Pentax 67 TTL prism meter window not visible vmixer Pentax Medium Format 8 11-15-2011 07:54 AM
P67 TTL prism not metering correctly? noodle0 Pentax Medium Format 5 09-17-2011 10:51 PM
All times are GMT -7. The time now is 06:36 AM. | See also:, part of our network of photo forums!
