03-22-2015, 01:55 AM   #31
The Madshutter's Avatar
QuoteOriginally posted by 2351HD Quote
How does the 645 to K adapter work with the DA lens? Nobody has been able to show me how this would work.
I am afraid it probably wouldn't be very practical - since there is no electronic communication between the adapter and the camera, and since the 25mm has an electronic diaphragm, you wouldn't be able to change your aperture neither from the lens nor from the camera. This aside, you should be able to use MF without any problem.
03-22-2015, 03:25 AM   #32
QuoteOriginally posted by The Madshutter Quote
The D-FA and DA lenses have a aperture lever that is mechanical, so if you have a 645-k adapter, does that control the manual aperture lever?
03-22-2015, 03:37 AM   #33
See here:
Pentax-K Adapter for 645 Reviews - Pentax K-mount Teleconverters and Adapters - Pentax Lens Reviews & Lens Database
"You will have to use stop down metering as the adapter neither has aperture contacts nor an aperture stop down lever". So no, you'll have to manually control your aperture - but at least you will be able to do so, whilst with the 25mm there is no way for you to manually control the electronic aperture of the lens.
Best,
Vieri
645d, 645z, barrel, camera, lens, medium format, movement, pentax da25mm barrel
DA25mm 645 lens Internal Filter options? Thomasbrowphoto Pentax Medium Format 7 03-31-2015 10:26 PM
Nature Movement gildedfool Post Your Photos! 3 11-09-2014 03:42 PM
Pentax-F 35-70 front barrel came off!? coppelano Troubleshooting and Beginner Help 5 09-23-2013 04:56 PM
Pentax DA* 16-50 lens barrel movement(?) Egg Salad Pentax SLR Lens Discussion 8 02-05-2010 06:48 AM
Pentax FA 80-320mm - loose front barrel jeallen01 Pentax SLR Lens Discussion 4 01-26-2009 01:23 PM
All times are GMT -7. The time now is 03:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
