04-05-2015, 06:16 PM   #1
Spider pro handstrap for 645z ?
Has anybody already tried this with the Z ?
https://spiderholster.tilt.com/the-spiderpro-hand-strap
cheers
Stephan
04-06-2015, 02:31 AM   #2
Chris Giles's Avatar
The current spider base doesn't seat properly on the Z. I use one and it's secure, but not flat on the bottom of the body. You might find a bit of movement in the strap position as a result. They are very good straps though.
As part of a spider belt system I have my concerns you'll get snagged on door handles.
04-06-2015, 02:44 PM   #3
thanks Chris, but the only doors that could be effecting, would be the battery, right?
04-06-2015, 06:40 PM   #4
I was going to order it but B&H says it isn't available until the 15th so I ordered this instead:
https://www.amazon.com/gp/product/B00B605UNA/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
This one is much less expensive so hopefully there's no complaints.
04-07-2015, 12:55 AM   #5
QuoteOriginally posted by zobeleye Quote
I think you can unclip it to access the battery (whilst keeping the base plate in there).
I think, don't quote me.
11-10-2015, 03:44 PM   #6
Spiderpro Hand Strap on the 645z
I've been using the Spiderpro Hand Strap on the 645z for a few months now and am very pleased.
11-11-2015, 01:00 AM   #7
I've bought the spider for my 645z and I found the Z has eyelet lugs thicker than usual so you have to force it to fit. There is no problem with battery access.
645d, 645z, camera, handstrap for 645z, medium format, spider pro handstrap
Pentax 645z and Capture One Pro tk78 Welcomes and Introductions 7 09-14-2015 03:09 PM
Pentax 645Z and Capture One Pro mrclark321 Pentax Medium Format 6 12-15-2014 07:56 AM
Wo/man's best friend! (Handstrap suggestions) mccarvindh Pentax K-01 7 02-07-2014 02:25 PM
Capture Camera Clip vs Spider Pro holster DaveR Pentax DSLR Discussion 3 01-11-2013 03:08 PM
Handstrap philippe Pentax Camera and Field Accessories 14 07-03-2009 07:41 AM
All times are GMT -7. The time now is 06:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
