The 120mm macros (A or FA) are very highly regarded (and is the only focal length available in the 645 mount - aside from the extremely expensive 90mm dfa)
An alternative would be the 100mm or 135mm macros for the 67 mount (you'd need an adapter, and most people rate the 100mm as a better lens, so the 135mm is the cheapest option - assuming you can find a cheap 67 -> 645 adapter, which can be done, but it may take you a while)
A cheaper option would be some extension tubes, or better yet, a helicoid extension tube).
