Originally posted by Canuck_west It's been awhile since I had a 645, but did you load the film properly? You have to ensure you put the film on the feed side, fed it with the black side out, and that the tongue is engaged in the slot, and that you wound to the arrow. You might have to waste a roll to check.
If the film is loaded correctly, then I'd say you have a problem.
Thanks for your help. Yes I believe I have the film in properly but it looks like the camera back seems to have trouble advancing the film. It almost was if the gears on the camera/film back were not reaching the gears of the camera body. When I attach the film back to the body of the camera with a roll of film threaded on it, the camera would try to engage the camera back to advance the film with no luck.
