08-04-2015, 08:30 AM   #16
Apotessar's Avatar
Maybe the lenses from 100 mm up will work without dark corners. Search for Flexbody and image circle, you will find every information you need.
Here is one Thread from LuLa: Image-circle of Hasselblad V lenses?
08-04-2015, 08:48 AM   #17
find information on the hassel of the image circle v is not easy in these months, I found a few more lenses that work well in 67.
110mm f2
50mm 2.8
150mm 2.8
These lens f, f are the latest findings.
The doubt will be that these lenses are better than the Pentax D-fa lenses?
08-04-2015, 09:04 AM   #18
QuoteOriginally posted by willeisner Quote
have a doubt which cable used to connect the lens to the flash? I have a 540 fgz.
It seems that the f5p has different entries lens.
I think you are asking about the cable to connect your 540FGZ to the pc on the lens. There are a few ways.
I use a strong flash grip and a cable that has a "pc male" on one end and a "1/4-20 threaded hotshoe"on the other.
This cable, I recall, came from B&H. The flash shown here is the Pentax AF360FGZ
Works on the Takumar 6x7 90 LS (top photo) and also on the RB67 ProS lenses (lower photo).
08-04-2015, 04:47 PM   #19
Thanks for sharing, great way to work, modern flash with old cameras.
645d, 645z, camera, format, hasselblad, lenses, medium format, pentax, sonnar
Compact Hasselblad anyone ? jpzk Non-Pentax Cameras: Canon, Nikon, etc. 11 12-15-2014 02:26 PM
67 lens with 67 extension tubes on 645d fatboy22 Pentax Medium Format 3 06-28-2014 04:44 PM
P645NII, 67>645 Adapter, 67 Auto Extension Tubes? ASA32 Pentax Medium Format 4 05-24-2013 09:27 AM
All times are GMT -7. The time now is 01:23 AM. | See also:, part of our network of photo forums!
