06-26-2015, 01:00 AM   #1
Exposure Bracketing on 645Z
Hi
Is there a way to get the camera to use shutter speed instead of aperture when choosing exposure bracketing in manual mode?
Lasse
06-26-2015, 01:33 AM   #2
Kolor-Pikker's Avatar
No, you switch to aperture priority mode.
Since Av works based on the camera's metering, you have to set exposure with EV compensation.
06-26-2015, 04:46 AM - 1 Like   #3
Fogel70's Avatar
QuoteOriginally posted by Lasse74 Quote
Hi
Lasse
I believe it depends on how you set the function for the green button. (P Line, Av-shift or Tv-shift)
So if you want shutter speed bracketing you set the green button for Tv-shift.
06-26-2015, 06:45 AM   #4
QuoteOriginally posted by Fogel70 Quote
That's not what it's for... let's say you're photographing outdoors in the shade and have the camera set to f/4.5, 1/250th and ISO100, and then you go out into a sunlit area and suddenly f/4.5 is too bright. Now, you could look at the meter and adjust the aperture to match, but it's potentially much faster to hit the green button, that if set to Av shift, will automatically set the aperture to a value the meter thinks would be appropriate. For instance, if it gave you +1.7EV at f/4.5, then hitting the green button will give you f/8 and show 0.0EV because it's now at the correct exposure value, according to the meter. Same thing goes for Tv shift - it's basically a one-press Av or Tv mode when you need it.
06-26-2015, 07:20 AM   #5
Fogel70's Avatar
QuoteOriginally posted by Kolor-Pikker Quote
Yes I know, but it also affect what setting will be bracketed in manual mode. At least on k-mount cameras.
Pentax K5 Aperture in Manual Bracketing | A Viewfinder Darkly
06-26-2015, 08:42 AM   #6
Hmm, last few times I've bracketed shots in manual mode it ended up changing both values, I'll have to do some testing to see if changing the setting does anything.
06-26-2015, 01:24 PM   #7
rcdurston's Avatar
I ran into this issue a while back and NO, there is no way to do it in manual mode.
Sucks.
I can't/don't want to use AV or any other auto mode.
Other manufacturers have got this right, come on Pentax its your turn to write some new firmware.
R
06-27-2015, 11:26 AM   #8
Thanks for posting this! You would not believe how long I have searched for a way to make my Pentax 645's do Tv-shift-only auto-bracketing in manual mode, when used with lenses lacking a manual aperture ring. I have never encountered the advice to change the green button function, but you're exactly right -- setting it to Tv-shift now has my cameras (both 645D and 645Z) working the way I've wanted them to with auto-aperture lenses, for the past 4.5 years. Post of the year vote for me.
Once again, a big THANK YOU!
06-28-2015, 02:14 AM - 1 Like   #9
Huh... well screw me sideways, it does work if you switch the green button to Tv priority, talk about cryptic functionality!
Edit: I don't think that this is going to affect me too much though, with the Z's dynamic range there are few shots I can't get in one shot, but the more you know...
07-10-2015, 03:00 PM   #10
Well I am impressed, could not figure this one out and never would have. Thank you Fogel70!
08-09-2015, 12:42 PM   #11
Ditto from me. A while back I had posted the same question elsewhere in the forum, with no resolution. Thanks Fogel70!
Pentax programmers please don't be so cryptic!!
645d, 645z, camera, exposure, medium format
Exposure Bracketing Problems Biggzie Pentax K-3 25 04-11-2017 09:28 AM
Exposure Bracketing on "M" lenses chickenandavocado Pentax SLR Lens Discussion 8 02-10-2015 11:09 PM
Exposure Bracketing gordon_l34 Pentax K-3 3 06-08-2014 05:48 AM
HDR/Multi-exposure/Exposure Bracketing sany Troubleshooting and Beginner Help 4 04-24-2011 08:52 PM
Exposure Bracketing on the K-x noahpurdy Troubleshooting and Beginner Help 7 12-26-2009 10:28 PM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
