The stabilization takes time to engage and for the actual elements to stabilize. This happens very fast, usually is done by the time the camera locks the AF so when using the shutter button for both AF and shutter release by the time you do a full press (to release) the picture has been stabilized.
When using the back button to engage AF (with the shutter button decoupled so it doesn't engage AF at half press, just for release), when you lock on a subject and press the shutter, the stabilization never engages. If the shutter button hasn't been decoupled, when using the back button to engage AF - you get a focus lock - but if you half press the shutter then the focus has been reset and the framing you've achieved by recomposing is ruined since half pressing the shutter will now refocus on the subject.
The back button AF should engage the stabilization in the lens.
Also, I use the latest 1.21 I believe fw.
Originally posted by 672 the late firmware has a choice of IS activations in the custom settings menu. and what is the use of AF button + IS if you are not gonna hit the shutter button. why does the AF button have to start the IS?
