08-29-2015, 08:47 AM   #1
pentax 645 compatible your 67
today I discovered something different, I tested two lenses 645, 300mm A* and A 35mm 3.5 and both cover the image circle of 67.
it is theoretically possible to use these lenses in larger format the problem is the distance
flange, which do not allow focus. Perhaps some sort of adaptation to use these lenses is possible in the body 67
08-29-2015, 10:45 AM   #2
You would need to extend the focal length of the 645 lenses to be able to reach the film on the 67. Putting a weak negative achromat in front of the lens would do this, however those are not made for such purposes. The 1.4X rear converter for the 6x7 is a negative lens (afocal) but there is no guarantee that this would extend the focus long enough when used on the front of the 645 lens. The 1.4X converter will also greatly reduce the amount of light entering the lens.
645d, 645z, camera, lenses, medium format
What do you consider to be the sharpest Pentax 645/67 lens in your kit? Thomasbrowphoto Pentax Medium Format 52 07-18-2015 05:07 AM
For Sale - Sold: REDUCED: 67-645 adapter [SOLD: Two 645 Bodies, A-Lenses 200mm, 80-160mm] AquaDome Sold Items 7 10-10-2014 09:57 AM
Pentax 645, 67, Mamiya RB and 645... My head is spinning. fretlessdavis Pentax Medium Format 40 11-22-2013 09:52 AM
Wanted - Acquired: Pentax 67 to 645 adapter mikeSF Sold Items 9 09-14-2013 04:48 PM
All times are GMT -7. The time now is 05:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
