09-13-2015, 04:09 AM   #1
Pentax 67ii time process issue
Hi,
Thanks for your help.
I am having problem using time exposure mode.
I have the AE Prism finder attached to the camera body.
I am moving the time exposure lever out after
1) setting the aperture
2) winding the film lever (film is not loaded)
then I press the shutter fully ( is this right ? )
A) Do I set time by moving shutter speed dial to A(aperture) or time or B (bulb) ?
The shutter opens and it closes after the set time is over.
It happens even if I do not push the time exposure set lever back in.
Is this how the time exposure is supposed to work?
09-14-2015, 09:44 AM   #2
Hi, thanks. I do have the pdf copy of the file and also the printed version. However, what is said in there does not work for me. I might also be not reading the implied stuff correctly.
09-23-2015, 09:58 AM   #3
Sorry, I am just feeling lost on this.
I am trying to understand the Pentax 67ii timer , power saving mode for long time exposure.
I believe that the following steps need to be done:
1) One selects the aperture by turning the aperture ring on the lens .
Which position should the shutter speed dial button be in : A , B or duration required ?
2) slide out the timer process button
3) wind the film button
4) is AE prism finder or one of the prism finders required ?
5) press the shutter release button
The shutter opens and closes automatically when the time lapses ?
Is my understanding correct ?
09-24-2015, 07:58 AM   #4
gofour3's Avatar
QuoteOriginally posted by csanjay Quote
Yes the P67ii manual is a bit fuzzy when it comes to the power saving long exposure mode.
My take on it that when you move the lever out and press the shutter it will remain open until you move the lever back. Which means the shutter speed dial is not used and the AE prism is not required as no metering is done.
Phil.
10-14-2015, 09:24 AM   #5
thanks for your reply
01-18-2016, 09:20 AM   #6
Hi,
I got it serviced and it works. Updating here for anyone interested in this in future:
I got info from person on FB who saw my post and replied.
1) Set the aperture after switching on camera
2) wind the film
3) Prism finder is not needed
4) It works even without film
5) set exposure mode to B
6) push out time exposure ( PS time) lever button
7) press shutter button fully - shutter will open
8) push time exposure button back
9) shutter will close
Tested my camera and this is how it is working now.
645d, 645z, 67ii time process, ae prismfinder, camera, exposure, film, lever, long exposure, medium format, pentax 67ii time, pentax67ii, pentax6x7, shutter, time
Pentax 67ii timer process query csanjay Troubleshooting and Beginner Help 1 01-18-2016 09:16 AM
Pentax K3 Time Lapse Issue! Korus Pentax DSLR Discussion 11 08-17-2015 01:37 AM
Pentax 67ii issue bigdaddyg Pentax Medium Format 4 11-03-2014 04:07 PM
Pentax 67II time exposure button question rustyair Pentax Medium Format 8 10-11-2013 07:17 AM
67II Frame Spacing Issue RawheaD Pentax Medium Format 10 05-05-2011 10:43 PM
All times are GMT -7. The time now is 11:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
