09-13-2015, 09:35 AM   #1
TheLens's Avatar
I thought the 645 had died.
Yesterday I attempted to load the 645 with film after not using it for about 6 months. When I pushed the shutter button, it tried to wind a little bit then clicked. I took the back out and attempted to fire the shutter and nothing. hen I decided to check the batteries-each AA registered 1.15 volts instead of 1.5 on the voltmeter. I put new batteries and it loaded the film like it should. What a relief! The batteries have only been in it about a year and 3 months.I need to remember that parts of the LCD stay active even when it's off and it still consumes battery power. Would it be better to remove the batteries when I'm not using it or just leave them in and replace about every 8 or 9 months?
09-13-2015, 10:59 AM   #2
If you don't use the camera for six months, you're better off taking them out. Why risk damage from battery leakage? And just keep a set of spares in your bag. Why risk not being able to shoot for something as trivial as some alkaline AA's that are so cheap in bulk at warehouse stores These are rated to hold charge for ten years.
09-13-2015, 01:07 PM   #3
lsimpkins's Avatar
QuoteOriginally posted by TheLens Quote
If the batteries are alkaline, they should be removed. If they are Lithium ion, or NiMH, they are probably OK to leave in the camera, except for the noted battery drain even when the camera is off.
645d, 645z, batteries, camera, film, medium format, months, shutter
Just when I thought I had seen it all Lowell Goudge Pentax SLR Lens Discussion 6 11-15-2011 02:16 PM
And I thought I had CBA boriscleto General Talk 4 05-12-2011 12:10 PM
I thought I had made a bad deal... Jimfear Pentax SLR Lens Discussion 20 08-10-2009 07:46 AM
I wish I had thought of this first mithrandir General Talk 6 03-31-2009 04:36 AM
Wow! I thought I had bought a good camera system racinsince55 General Talk 11 06-13-2008 04:19 PM
All times are GMT -7. The time now is 01:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
