09-18-2015, 11:05 AM   #1
Need help diagnosing the Pentax 6x7 I got
Hello everybody
after quite some time casting an eye on a 6x7/67 I bought a 6x7 body from overseas for what I conisidered quite a good price.
I got it in the mail today and from what I understand it looks like an early model with the silver lens release switch and no MLU. First thing I did was reading the manual and put in a fresh battery (measured the voltage and works fine in my Mamiya 645 bodies). Did a battery check and the LED lights up just like it should.
I followed the instructions to get it to dry fire by setting the exposure counter to 1 or more while having the back open. Now here is the problem:
I cannot advance the winding lever. It is not completely stuck; I can get my thumb behind it but not more and I know enough about cameras not to force it. It feels as if it has already been advanced/cocked and maybe it is but when I push the shutter button nothing happens (I know about the shutter lock). From what I read in the manual the winding lever should also spin freely when the camera is not in "dry fire mode" but it does not.
The mirror is down and the shutter closed. They look fine from what I see. I also tried the small reset button but no reaction either.
I already googled for hours but couldn't find a case like this. Most of the issues with the 6x7/67 shutter and mirror mechanisms seem to be related with the internal solenoids and the mirror hangs when it's up or problems only occur at certain speeds. I can't get the mirror to move at all.
It would be really great if I could get any input or some thoughts on this issue. Obviously my timeframe for this is limited and if I don't get it to work I have to try to send it back in time with all the hassle (considerable overseas shipping & taxes plus hope that the seller is not reluctant).
09-18-2015, 02:43 PM   #2
With the back open you have to turn the dial past 1 to 2 or 3 and hold it with your thumb as you close the door-then advance lever and fire. Mine's always worked like that.
If you have a reset button on the front of the camera you have a MLU camera.
09-18-2015, 03:51 PM   #3
Thanks for your reply.
QuoteOriginally posted by ColColt Quote
Yes, that is what I did.
This one has a reset button on the front under the "6x7" lettering but no lever for MLU.
The winding lever cannot be advanced when it is not in "dry fire mode" either. From what I understand it should be possible to move the winding lever freely when there is no film inside shouln't it?
09-18-2015, 04:02 PM   #4
If the reset is not for the mirror what does it do? That puzzles me. The film advance lever should indeed move freely with no film in the camera. do you have a LS(leaf shutter) lens on the camera?
Something to try. Push in on the reset with pencil or whatever you have and at the same time try the shutter button.
09-18-2015, 04:31 PM   #5
It is for the mirror when it gets stuck part way or all the way up on the non-MLU cameras (Honeywell and Asahi). Just because you can't lock the mirror, doesn't mean it can't hang up. Of course the MLU cameras have this as well.
09-19-2015, 01:55 AM   #6
No I don't have a lens yet.
Reset & shutter button does nothing. I didn't expect the reset button to help anyway because like desertscape wrote: The mirror is already down all the timein my case ...
645d, 645z, 67, 6x7, battery, button, camera, fire, lever, medium format, mirror, pentax 6*7, pentax 67, pentax 6x7, shutter, stuck, time, troubeshooting
I need help. Something got into the lens. lesshair Troubleshooting and Beginner Help 11 02-23-2014 06:51 PM
Just got my k5 and I need help Mtnberner Pentax K-5 16 10-24-2012 03:48 PM
Need help ASAP!!! I've got 16hrs HoBykoYan Pentax SLR Lens Discussion 28 10-09-2012 02:29 AM
Need help diagnosing back focus problem klh Troubleshooting and Beginner Help 22 06-18-2012 05:13 PM
So I need some help...I just got a sunpak 383 for my K10D. triplej96 Photographic Technique 6 05-06-2008 04:39 PM
All times are GMT -7. The time now is 04:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
