09-19-2015, 11:36 PM   #1
645z camera and transfer photos on Pc
Hi
I see my photos on 64z monitor camera in right position (up) and when i transfer photos on PC and open with lightroom a get my photos upset. Can i get them directly in right position?
sorry i am i beginner with pentax!!
thanks a lot
09-20-2015, 01:33 AM   #2
Check custom function #22 and make sure that rotation info is being saved in your files (the default).
09-20-2015, 02:49 AM   #3
This happens to me as well, shooting RAW and when imported, they are upside down, when I convert to Tiff from Raw, I just rotate the whole lot in one go from ACR
09-20-2015, 11:07 PM   #4
Thanks a lot; i will try.
Luc
09-21-2015, 01:30 AM   #5
Does this happen when you shoot JPEG, or just RAW, or both?
If you open the JPEG on your PC - and without letting Lightroom touch the file in anyway - is the orientation OK? If yes, a Lightroom setting may be the problem.
09-21-2015, 01:32 AM   #6
QuoteOriginally posted by sanluc Quote
Luc
Hi
custom function #22 in in on position, but the photos are upsite in Pc. There are a combinations of settings for getting the up position?
Thanks a lot for your patience.
Luc
09-21-2015, 03:17 AM   #7
Kolor-Pikker's Avatar
Open up your camera menu and select "image capture settings", at the bottom is "180 Rotation Info", make sure sure the check box is empty, turn it off if it's not.
This happened to me too the first time I used the camera.
09-21-2015, 05:42 AM   #8
QuoteOriginally posted by Kolor-Pikker Quote
Hi
Ok the right settings are:
custom function #22 and check n. 2
In this mode In Lightroom the photos (raw files) are up! also if i open them with preview with mac.
thanks a lot
camera, pc, pentax help, photography, photos, position, transfer, transfer photos, troubleshooting
off camera flash on 645z gavincato Pentax Medium Format 12 07-27-2015 06:44 AM
Photos on SD card not visible after turning camera off and on. kenny47 Pentax K-5 12 05-17-2015 10:56 AM
Phillip Bloom added 100+ photos from his 645Z on Facebook MyTZuS Pentax Medium Format 4 03-04-2015 09:50 PM
Photos transfer to PC Frankie500 Photographic Technique 2 09-08-2009 02:46 AM
What do you use to Transfer/Import photos from memory card to PC? buckethead Photographic Technique 8 04-09-2007 07:11 AM
All times are GMT -7. The time now is 08:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
