09-29-2015, 03:34 PM   #1
Locked up Pentax 67II
I have a recently acquired Pentax 67II with an issue. Initially the camera was locked up. The shutter would not fire and the film take up reel did not advance (though the advance lever does move freely). After some putzing around, it started to work. I was able to load film and advance to "1". Now, it's back to the same issue. It will not advance nor fire.
I have replaced the batteries. Any other thoughts as to what it could be ? The previous owner had run film through it just 2 weeks ago.
If it comes to repair, who works on these ? I've already contacted Eric Hendrickson and he no longer works on the 67II.
Thanks for your help.
09-29-2015, 06:46 PM   #2
gofour3's Avatar
Welcome to the forum!
- Are you using the AE metered prism with your 67ii?
- What is the shutter speed dial set to, or have you tried various settings and the same thing happens?
Phil.
09-29-2015, 11:01 PM   #3
QuoteOriginally posted by gofour3 Quote
Phil.
I've tried the metered prism and waist level with the same result. I just ran through all the shutter speeds with the same locked up result.
09-30-2015, 12:44 PM   #4
Royal Camera Service in Hanover Park, Illinois (630) 372-6150 repaired one of my two Pentax 67ii this past Spring. I had an issue w/ film advance lever also...
09-30-2015, 03:46 PM   #5
gofour3's Avatar
QuoteOriginally posted by UnkleSamo Quote
That seems to be the main issue with the P67ii body. Ricoh/Pentax Japan was servicing the 67ii, not sure if they still do.
Phil.
645d, 645z, 67ii, advance, camera, film, fire, issue, medium format, pentax
Misc Locked up and waiting for Summer NKK Post Your Photos! 3 11-24-2014 10:23 AM
replacement motor of a locked up mirror zimmicha Visitors' Center 5 02-11-2014 10:15 PM
Pentax 67II Film Body locked up? Pentax645DTether Pentax Film SLR Discussion 6 11-23-2013 09:54 PM
K10d Locked-up Wethphotography Pentax DSLR Discussion 18 02-05-2007 09:15 AM
All times are GMT -7. The time now is 01:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
