Originally posted by Simen1
Does it exist a 67 lens to K mount camera speed booster?
NO.
what does it take to make one?
At least a Masters in optical design and engineering, access to optical production facilities and optical multi coating facilities, you can't just buy an optical element or two off the shelf, there are hundreds of variables in optical design that need to be calculated and designed into an optic such as this.
Can astronomy telescope shops provide focal reducers with large enough image circle and good IQ?
NO.
use a 0.5x reducer to reduce a 100mm f/2 lens to effectively 50mm f/1
For all the time and tedious tinkering you would be better off buying a Leica and a Noctilux. I own three of the Noctilux (noctili?) lenses Leica has made and to be honest, f/1 is an aperture I only use when I absolutely have no other choice, as have many other photographers who have worked with such lenses have concluded.. Bokeh from the Noctilux (even the current 50mm f/0.95 ASPH) is either gorgeous, or so ugly you'll want gouge your eyes out with a spork....and question why you spent so much on a lens.
