12-01-2015, 03:52 PM   #1
Changing autofocus point in 645z
Ugh. Haven't used this camera in awhile and have forgotten how to change from one autofocus point to another. I thought I had to hit the AF Area button and then use the four options around the "OK" button to move it around, but that's not doing the trick. What's the procedure to move the little devil around?
12-01-2015, 03:56 PM   #2
QuoteOriginally posted by dShelly Quote
That should do the trick, but you have to be in the appropriate focusing mode (i.e. select) to be able to change AF points to begin with. That option is available in the control panel (info button).
12-01-2015, 04:09 PM   #3
No, that's not doing it. It's really quite ridiculous that the AF points can't be moved in the same quick and easy manner that Canon uses.
12-01-2015, 04:33 PM   #4
Are you shooting live view or viewfinder?
12-01-2015, 05:01 PM   #5
Autofocus via viewfinder.
12-01-2015, 05:45 PM   #6
unkipunki's Avatar
hold down af select button. Rotate rear dial until sel appears on the rear screen. Release af select button. Press the button above the red live view button select point with four way controller. Press button above live view button to return to normal four way controller usage. From memory but it is a lot easier than it sounds
12-01-2015, 06:20 PM   #7
Thanks! I'll give it a try.
12-02-2015, 03:14 AM   #8
Or press the button with small arrows on it before operating the D pad. This swaps the modes on the buttons from the features to focus point selection. Well it does on mine, anyway!
12-02-2015, 04:57 AM   #9
unkipunki's Avatar
QuoteOriginally posted by itshimitis Quote
Not if it is set on centre 'spot'. The small arrow button does nothing in that case. The AF area mode needs to be changed as I described above to one with 'SEL' before a specific point othere than centre can be selected. If you live with the camera in SEL mode then yes just tapping the 'arrow' button and using the four way controller will work. If you are in Centre Spot it will do absolutely nothing.
12-02-2015, 06:43 AM   #10
QuoteOriginally posted by unkipunki Quote
Thanks for that. I'm so used to being in SEL that I'd forgotten about everything else!
12-02-2015, 12:15 PM   #11
That worked. Thank you!
645d, 645z, autofocus, button, camera, medium format, move
Changing focus point Zapper Pentax K-3 4 11-25-2014 03:16 PM
5 point autofocus vs 11 point. slip Troubleshooting and Beginner Help 8 09-22-2014 08:56 AM
K5 Autofocus Point charleychen Pentax K-5 5 04-01-2011 11:38 PM
question about changing AF point sholtzma Pentax K-5 3 12-16-2010 11:39 AM
K-7 Changing AF Point walro Pentax DSLR Discussion 3 04-15-2010 07:06 AM
All times are GMT -7. The time now is 11:52 PM. | See also: NikonForums.com, part of our network of photo forums!
