Originally posted by mattb123 It would be me front or back focusing because it's the A version, manual focus. Definitely a possibility and I do rely on the focus confirmation but it seems spot on without the TC.
The tripod probably isn't as big as it should be. I'd like a bigger one as funds allow. I never use the center column unless that is the only way to get the shot.
I thought the 2s timer did a mirror lockup when you hit the button which gives the vibrations 2s to dissipate before the shutter fires. Am I mistaken about that?
I'll keep experimenting and report back any significant observations.
Thanks!
I thought that even with MF lenses, AF fine tuning would help with focus confirmation with that lens, but I'm not sure. If it seems spot on w/o TC, then it probably is, but the TC essentially creates a new lens with more elements and groups.
In terms of tripods, another advantage of carbon fiber over metal is that it transmits less vibration. Wood is the ultimate, but impractical without a sherpa.
The 2s mode on the 645D self-timer raises the mirror and activates the shutter at the same time.
The reality of your situation could be simply, as you put it, the inherent loss of IQ with a 2x TC. It is essentially cropping optically to the center of your lens. With a loss of two stops, resulting in slower shutter speeds or higher ISO, I question whether it is worth
the compromise. Yes, cropping your medium format sensor reduces it to a FF, but does that loss of pixels worth the loss of resolution from the lens or increased diffraction?
Hopefully this is all just speculation and it's more of a vibration issue and not resolution. I would try ISO 800 and get the shutter speed as fast as possible with the lens only stopped down 2 EV.
