11-12-2018, 05:31 PM   #16
Silent Street's Avatar
A sticking/lazy solenoid controlling the mirror activation/mirror lock-up is a well-known problem in all Pentax 6x7, 67 and less commonly, the 67ii camera. If the fault is intermittent, reliability is compromised, inconveniently when it is needed most! Have the camera professionally assessed and serviced to address this problem, usually involving a spray, and a few repeated activations to remedy. Replacement, if needed, comes from another camera, not new. There is quite a bit of disassembly involved followed, by calibration back to original tolerances.
The mrror reset on the vintage Pentax 6x7/67 cameras is only used in the event of accidental activation of the mirror lock-up with the shutter cocked, or in the event of a flat battery. In either and both cases, a frame is sacrificed as a normal step in the reset process.
645d, 645z, batteries, battery, camera, huh, issue, issues, medium format, minutes, mirror, nikon, pentax 67ii, roll, shots, speeds, switch, weather
Why oh why is the 15mm Limited lens not fully weather sealed? Diego Pentax SLR Lens Discussion 10 08-10-2013 07:20 AM
*ist DS(2) not recording...blank images (in cold weather) ramblinman Troubleshooting and Beginner Help 4 03-10-2011 05:26 PM
Pentax lens in cold weather. Pentaxguy22 Pentax SLR Lens Discussion 8 04-14-2010 01:12 AM
Is this a good Pentax 67II deal ? ghelary Pentax Medium Format 4 11-27-2009 04:11 PM
K2000 in the cold weather- ok or ?? Sew-Classic Troubleshooting and Beginner Help 9 10-30-2009 04:46 PM
All times are GMT -7. The time now is 07:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
