01-09-2016, 12:47 PM   #1
mattb123's Avatar
SMC Pentax 67 300/4 on 645
I just got this lens from Japan pretty cheap and thought I'd give it a try based on MikeSF's results with a similar one.
I'm using the Photodiox 67 to 645 adapter for my 645D. I put flat black paint inside the adapter as I have heard needs to be done for reducing reflections.
Everything seems to be good but I'm curious about how this lens/adapter/body combo all works together.
Is the 645D mount "crippled" like the K mount is for old lens aperture adjustments? Or can I somehow get feedback on the D when changing the aperture ring? It looks like there are two levers in the 645 mount to do that.
I'd love to see the D recognize the aperture setting if possible, and ideally control it. Is either of these things possible? I didn't see that "Allow use of aperture ring" setting in there but the lens has an auto/manual switch I imagine is for aperture. I'm hoping that will allow what I'd like to see but I could also live with stop down metering via the green button if need be. I do that with some old Leica glass on K mount and it works well enough.
Just want to get the gist of how these can best work together. Thanks!
01-09-2016, 01:42 PM   #2
Ole
Ole's Avatar
The 645D mount is not crippled, so you can shoot with open aperture metering in M and Av exposure modes if the adapter supports it.
I have used 67 lenses on the 645D and Z with a genuine Pentax adapter with no problems.
01-09-2016, 10:02 PM   #3
Ed Hurst's Avatar
The camera understands the aperture you are using, but cannot control it (there is no way for any body to control the aperture on a Pentax 67 lens).
01-10-2016, 12:26 AM   #4
I use the 300mm and 135mm with adapter. so far so good iq is fine.
01-11-2016, 10:54 AM   #5
mattb123's Avatar
QuoteOriginally posted by bull drinkwater Quote
Is it the Fotodiox adapter? Does your camera know what f-stop the lens is set to?
01-15-2016, 04:09 PM   #6
QuoteOriginally posted by mattb123 Quote
it's a pentax adapter, I was lucky to find. all camera functions work. it's manual focus and the 300mm needs a lens support. my setup works from a tri or monopod.
01-16-2016, 11:40 AM   #7
So, did you get the M* 300 or the older version that used conventional glass?
01-16-2016, 12:03 PM   #8
mattb123's Avatar
QuoteOriginally posted by desertscape Quote
I think it must be the older version. It just says SMC PENTAX 67. Haven't done anything with it besides some test shots so far.
I can see the aperture lever on the adapter move when I change the aperture ring but the camera always shows F--- on the display.
SM-G900V  Photo
645d, 645z, adapter, aperture, camera, lens, medium format, smc pentax
Removing front lens section on SMC Pentax 67 1:4 200mm xyzzy Pentax SLR Lens Discussion 10 05-20-2021 03:58 AM
SMC Pentax 67 300/4 bjolester Pentax Medium Format 32 07-30-2016 03:57 PM
For Sale - Sold: Pentax 645 120/4-A Macro, 300/4 SMC A* benroy Sold Items 17 11-13-2011 06:37 AM
All times are GMT -7. The time now is 11:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
