01-10-2016, 01:54 PM   #1
Pentax 67ii: Missing viewfinder piece?
Hello,
I own a Pentax 67ii with the AE Pentaprism finder.
The camera I bought was missing an eyepiece over the viewfinder - there is no plastic (or rubber) ring / no framing piece (or whatever it's called) that would fit into the viewfinder. I believe the missing part should be a small screw ring with grooves on the perimeter so it can screw into my viewfinder, possibly with a small plastic or rubber ring around the exterior for comfort.
I am wondering if anyone else has experience with this and if so, what is the name of the piece that I need (or even better, the part number)?
Attached is a photo of my viewfinder currently - perhaps you can see what is missing.
The reason I'm searching for this is because I cannot attach any rubber eyecups or other viewfinder accessories (such as a magnifier) without it. I bought a genuine 67 eye cup (part number 37410) to use when shooting in bright light, and there is no way to attach it to my viewfinder without this missing piece (there is nothing for the rubber eyecup to attach to on the viewfinder).
I do not think it will help me to buy a new diopter - any suggestions are welcome.
Thank you for your help!
Brian Ferry
IPhone 6s  Photo
01-10-2016, 06:48 PM   #2
gofour3's Avatar
Welcome to the Forum!
You are missing the prism eyepiece frame, which is removable for mounting accessories such as the right angle finder, magnifier and rubber eyecups.
You should be able to find one on eBay.
Phil.
01-10-2016, 07:33 PM   #3
Thanks, Phil. I appreciate the helpful reply.
One follow-up question, however - the rubber eyecup accessory that I purchased (part # 37410) needs to attach to something on the viewfinder -- so I am assuming that the original prism eyepiece (and frame) will allow me to do this. Do you know if that's true? If you look at the photo I posted of my viewfinder, you'll see that there is nothing there for an accessory to attach to (unless the accessory itself has a threaded ring, and the Pentax rubber eyecup accessory does not).
Hope this makes sense...
After more sleuthing on the forums today, I did find this thread which suggests that I need to get 4 different parts (my viewfinder looks exactly the same as the original poster's viewfinder in that thread). Perhaps that will solve my problem.... I'm going to call Ricoh US tomorrow and see what I can find.
THanks.
01-10-2016, 10:15 PM - 1 Like   #4
gofour3's Avatar
QuoteOriginally posted by brianwf1 Quote
Yep that should do it. My guess is that the former user removed the prism eyepiece frame to use the magnifier or right angle finder and did not replace it.
Hopefully Ricoh still has the parts, if not purchasing an old non metered prism for just the eyepiece frame is an option.
Phil.
10-18-2016, 02:20 AM   #5
Can someone help with the source for the Pentax 67ii eyepiece and the rubber that goes around it - Ricoh US " Ricoh Imaging does not deal direct with the consumer, only dealers. If your are a repair center I can send you an application fill out and send back to us for review, You can also send your camera in to one of our warranty centers and we will be happy to take care of it for you, or you can find a dealer in your area."
I just need the metal eyepiece tube and the rubber eye-cap that goes around the tube.
Thanks
10-18-2016, 04:02 PM   #6
Silent Street's Avatar
The missing eyepiece frame also contains the standard dioptre correction lens, so without it you may have difficulty focusing (unless you have the so-called "perfect" 20/20 vision).
I keep my Pentax 67 right-angle finder in an attachable pouch clipped to the tripod. When the eyepiece is removed (fitted with a rubber eyepiece cup), it is immediately placed in this pouch just before removing and fitting the right-angle finder. The previous owner of your camera has obviously let that piece come adrift somewhere, or kept it to put it on another camera. Organising good habits in managing easily lost parts, and sticking to those habits is the first step in preventing loss of critical components.
Is it possible the knurled eyepiece from a Pentax 6x7 / 67 will fit the 67II??
---------- Post added 19-10-16 at 10:05 AM ----------
eBay has rubber eyecups for the 67 / 6x7 and (probably) 67II finders. Don't fit the cheap and nasty Chinese-made junk as it cracks/splits with exposure.
07-11-2017, 07:02 PM   #7
I've come into the same problem. Mine came off while shooting.
Anyone have any other suggestions besides ebay?
04-19-2019, 07:54 AM   #8
Abram's Avatar
I am so sorry to resurrect this thread, but I am missing the exact components described above on a 67II that I recently acquired. Short of spending almost $400 on a new viewfinder just to harvest one part I seem to be unable to locate what I need. Has anyone found sources that could supply the standard diopters?
04-19-2019, 04:41 PM   #9
Rather than $400, a cheaper solution, if you cant find the eyepiece alone, might be to buy a older pentax 67 unmetered prism like this one:
?Exc+++++? Asahi Pentax 6x7 67 Prism Eyelevel Finder For 6x7 67 from Japan 343 | eBay
(be careful looking at prisms on ebay--a lot have had their eyepiece scavenged.)
The eyepiece looks to be the same (I can't guarantee it though). pretty good chance it has the standard diopter in it. If that doesn't work for you, then you can measure the glass and see if you can find replacement diopter glass of the right strength.
These guys probably have the glass needed, but I'd be lost finding it.
Optical Lenses - Optical Lens - Achromatic Lenses | Edmund Optics
04-19-2019, 08:03 PM   #10
Abram:When an accessory such as a rubber eyepiece is used on any of the Pentax 6x7, 67 and 67ii cameras, most require removal of the default dioptric correction lens (assembled into the knurled ring) and reassembly of this into the rubber eyecup. Having said that, I cannot see why you cannot attach a right-angle viewing attachment, because that requires removal of the dioptric correction lens and/or eyecup, presenting you with the bare-bones thread into which the right-angle finder is screwed -- shown in the original post on this subject. Note that the central-area viewfinder magnifier cannot be used without the knurled ring containing whatever dioptric correction lens assembled into it. Unlike the right-angle finder, the central-area magnifier is attached with the knurled ring -- a somewhat clumsy and annoying arrangement as it is tedious and presents the opportunity for the knurled ring to be dropped or at worse, lost!
A beat-up, non-working Pentax body with the prism (no matter whether it is TTL or non-TTL) in-situ, from which the eyepiece could be salvaged would be your best bet. All accessories for the viewfinder eyepiece are interchangeable back down the Pentax MF series.
04-20-2019, 12:15 PM   #11
Abram's Avatar
Well on my 67II it has a built in diopter correction but there is no eyepiece cover, it didn't come with my camera unfortuntely. I can work without it just fine I just prefer to have one there. I'm not looking for any corrective lens or any special attachments. I just want to cover up the eyepiece.
What I have currently looks like the first attachment (same as the OP), the eyepiece is missing. What I'm looking for is the part that is circled in the second image.
04-20-2019, 01:20 PM   #12
I believe that piece still has some glass in it, and the glass is replaceable. On the 67 the only way to adjust focus for people with vision issues is to replace the glass with something that magnifies. The standard glass is just glass and not a lens, but buying on the used market, you don’t know if the glass has been replaced with something else. I still think your best option is to replace it with an eyepiece from a older, preferably broken (to get it cheaper) prism from a 67 or 6x7. Since other 67/6x7 attachments like the right angle finder fit, it’s likely the eyepiece will fit too. It might look a tiny bit different (the ring is knurled on mine) but it’s better than not having one.
04-20-2019, 01:58 PM   #13
Abram's Avatar
I suppose I'll have to keep looking then, unless anyone has a parts source that I could contact?
04-20-2019, 01:59 PM   #14
gofour3's Avatar
Easiest way as previously mentioned, is to buy an old used 6x7/67 non metered prism and use that one. This metal screw in piece with the glass, is the same on any 6x7 prism.You will need this part to attach a rubber eye-cup.
Here is an example on eBay that also includes the magnifier:
https://www.ebay.ca/itm/Asahi-Pentax-6x7-67-Eye-Level-Prism-Finder-and-Angle...0AAOSwc6ZcEGaE
Phil.
645d, 645z, 67ii, 6x7, camera, eyepiece, finder, habits, medium format, pentax, piece, plastic, right-angle, rubber, screw, viewfinder
Viewfinder has metal piece showing EyeSpy Pentax Film SLR Discussion 12 03-31-2018 12:00 PM
Viewfinder/Eye Piece issue on 645N saralouisepetty Pentax Medium Format 2 08-27-2015 08:44 PM
Hotshoe flash piece missing, what do I do please? AuraTodd Troubleshooting and Beginner Help 7 03-16-2014 03:07 PM
Missing bellows piece? Yaro Pentax Camera and Field Accessories 3 07-06-2010 10:23 AM
All times are GMT -7. The time now is 11:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
