Originally posted by algrove Why not rent a 645D to see if that's the "look" you are after like the M8 or better yet the M9. Then again try renting the M246 to see how a B&W cam might work for you since you already have Leica M lenses.
Yes, thought of that.
What I was really looking for was a bit more of the MF file structure. I could get a M246 of course, but that would exclude 50MP files and larger sensors (which is literally the main reason I wanted a MF option at all).
In a bit I will post some of the Leica S files when I tested an S over a year ago. This was a S 006 body and CCD.
They required less processing, and yes, I typically start with VSCO PRESETS and tweak, but after I get it basically right in camera.
The only reason I went with a CMOS body, and the Z, was I thought the sensor may be a tad more dynamic if I decide to change it up.
---------- Post added 03-01-16 at 02:27 PM ----------
Originally posted by UncleVanya In my ignorance I will wade in. I think what you are missing is that no one is saying change the look of the shots. They are saying that if you want more nuanced blacks like the Leica seems to have - start by exposing differently and then batch process or manually process the files to a look closer to what you want. By exposing differently you will capture more detail - there is a tension obviously between highlights and shadows and I think they are of the opinion you have room for dropping your highlight headroom a bit to capture more details in the shadows - then when you crank it back to black you will have more nuance in the black than your have currently due to the 15 stops of dynamic range.
But I'm not shooting anything like this. So I'm just interpreting others.
I get it. Makes sense. I I'll shoot something today and tweak.
I just remember the CCD of the S was pretty much on top of it out of the box. Maybe I am expecting too much from the very dynamic CMOS Of the Z.
But maybe in time I will dig it more, like with the M240.
I like both looks really. And he CMOS is much better for a lot of things that the CCD isn't.
