03-09-2016, 03:21 PM   #1
Pentax 6x7 Test Without Battery
I just given a Pentax 6x7 with no battery, and I'm trying to try out the camera with NO FILM inside. I've read that you need to press down and move the shutter counter dial to trick the camera that there's film inside, which I'm able to do, but after pressing the shutter, it kind of jams; then I need to press that button in the front with a pen. Is this camera dead? Do I need a battery in order to continue testing the camera without film?
I'm not really planning on using it, and before I rush out to buy a battery, I thought I'd check here.
Any info appreciated.
03-09-2016, 03:50 PM   #2
Silent Street's Avatar
What are you doing??
The shutter requires power, through a solenoid, to fire. No battery = no power, obviously. The camera is designed not to fire unless film is loaded, to protect the shutter. True, you can bypass this in the manner you have partially described. After the reset button is pressed, the shutter must then also be pressed once to complete the cycle. But why are you doing all this? Why not just put in a battery, load a roll of film and use the camera as intended?
03-09-2016, 04:05 PM   #3
QuoteOriginally posted by Silent Street Quote
What am I doing?? I'm inquiring if this particular camera needs a battery or not to operate as some cameras don't have batteries at all and can work. As I typed, I don't plan to use it as it was given to me. I don't want to buy a battery and load a roll of film only to discover the camera is dead or whatever anomaly with or without a battery; hence, the question. Great. Now I got useful information, thank you, without having to buy a battery or load the camera.
03-09-2016, 04:13 PM   #4
As noted above, your camera requires a battery for the shutter to work and is designed to not "dry fire" (operate without film). This may be overriden by using the tool and procedure described in the camera manual:
Pentax 6X7 instruction manual, Pentax 6x7 prism finder, user manual, PDF manual, free manuals
03-10-2016, 06:55 AM   #5
LFLee's Avatar
QuoteOriginally posted by Cereal Killer Quote
You can dry fire 67 using two methods, as outlined in the manual. Easier one is without tool: with back is open, turn the counter dial pass 0, holding it that way, close the door. Now you can "dry fire" it, by cocking the shutter, and press the button.
However, without battery, the mirror will not come down after you fire. There is a button in front, where you can press and release the mirror back down, then you can cock the shutter again, and fire.
It's doable, please read the manual as my explanation may not be good enough (manual have picture to describe these).
03-10-2016, 08:31 AM   #6
Thanks everyone for the input.
03-14-2016, 08:33 AM   #7
Giveaway winner!
MysteryOnion's Avatar
No Battery - Test for shutter action verification and mirror return.
Here is a no battery test...if you just need to see if the curtains will work and if the mirrors are able to cycle....
You will need a pen, because it is sturdier than a pencil or you can use whatever will operate the reset button.
Set the body in to dry-fire mode...(back/film door open, thumb dial rotated past zero and hold, close the back/film door)
winding the advance lever.
push and hold reset button.
fire shutter.
let-go of reset button.
If you had removed the lens and observed the action, the mirror went up and curtain #1 sprung open, you see the pressure plate then when you let go, curtain #2 closed and the mirror returned.
The holding of the reset is the simulation of magnet holding for the exposure.
I hope this helps.
Do note that this does not verify if the advance is properly working or the clutch is in good shape and of course without the battery you are not able to verify if all the power switches or magnet is working.
03-14-2016, 01:23 PM   #8
klaus123's Avatar
If you do not have the right battery in hands for an initial test you can use 4 LR44 (fixed together with some tape).
Without a battery the mirror will be blocked half way and needs to be released by the (hidden) relese button on the front surface.
645d, 645z, 6x7, battery, camera, film, medium format, pentax, pentax 6x7 test, press, shutter
How to test DA300 mm without other 300mm lens? pukipuki Pentax SLR Lens Discussion 14 01-30-2016 03:14 AM
Pentax 6x7 MLU: Battery/Shutter/Mirror Problem. HELP! richard balonglong Pentax Medium Format 7 08-16-2015 12:39 PM
6x7 without MLU? keyofnight Pentax Medium Format 13 10-05-2012 06:06 PM
Pentax 6x7 Battery Psybenja Pentax Medium Format 3 06-29-2010 08:59 PM
Use Pentax ME Super without battery? iht Troubleshooting and Beginner Help 3 08-05-2009 10:34 PM
All times are GMT -7. The time now is 11:50 AM. | See also: NikonForums.com, part of our network of photo forums!
