Originally posted by 2351HD Thanks, I looked at the Kenti but there is no data to show the internal size.
Do you know what the measurements are?
I measured it for you
the internal dimensions of the lower (photo-)compartment are:
Height: 32cm
Depth: 13cm
Width: 25cm (bottom), 23 cm (at the top)
These are all aproximately, because it depends on your personal fitting of the bag.
For example: My 645D with FA 2.8/150mm with the lens shade in normal position fits perfectly in (vertically). With the DFA 2.8/90mm MACRO I have to reverse the lens shade.
Hope this will help you...
Edit: Another advantage is the fact that you can take the camera easily out of the bag (and back) just on swinging the bag sideways forward. The lateral opening is then upwards.
