Originally posted by 2351HD
What do you think about the contrast of the lens? I have found a lot of the FA lenses to be quite flat, compared to other lenses I have used in the past such as Leica and Zeiss glass. Obviously the Z raw files are quite flat because of the huge dynamic range, but you can tell when a lens has great contrast.
My first copy of the A 120 macro used from Japan was lackluster and I sold it. My 2nd copy is top notch, sharper and with better contrast than the 80-160mm (two copies). It is not as contrasty as modern Zeiss designs I've used, and as you noted the Z files import flat due to the extremely wide dynamic range. However, in my Lightroom workflow I am able to get as much global and micro contrast as I wish using the contrast and clarity sliders, and the resulting files and large prints are wonderful. At times I will also use the Huelight high contrast variant profile and that's another nice option for popping the global contrast at the beginning of the Lightroom workflow.
Cheers,
Ross
