Originally posted by dcshooter
If you consider that image to have acceptable quality even for a flat, distant landscape,
i clearly stated "
ignoring the obvious defects"
it should still be obvious from the right side of the pic what i meant by a flat field lens; it refers to field curvature design, not dof... most wide lenses would be mush on the sides at those wide apertures, due to field curvature and aberrations.
with ff you have many lens choices, so you can find a lens that is optimized for a flat focus field; with mf you only have one wide lens choice.
The maximum possible DOF scenario for a 35mm lens at f/2 is to focus dead on the minimum hyperfocal distance allowing for infinity. Using my handy dandy hyperfocal calculator, a subject with a maximum distance of 1000000 ft (infinity in practical terms) gives you a near limit/hyperfocal distance of 59 feet. Restated, 59 to infinity is the absolute minimum distance you can get in focus at that focal length/aperture combo and still have the far background/sky in focus.
at the f/2 minimal focus distance, the near limit/hyperfocal distance is actually somewhere around 33 ft, not 59 ft.
A Flexible Depth of Field Calculator
at the more realistic f/4 minimal focus distance, the near limit/hyperfocal distance is 16 ft, not 33.6 ft... etc.
our numbers are different largely because of where the minimal focus distance is at... so if i needed a close foreground object in focus, ff would have a slight advantage, at more usable wider apertures, assuming the right lens choice.
yes i focused well into the scene there, on the billboard, because i was testing the lens... it failed, lol, i returned it to b&h.
wrt diffraction, there are no dof advantages either way, because when the actual dof is equal(not the aperture numbers on the lens), so is the diffraction.
that's covered in detail here:
Equivalence
Really, the only scenario I can see where having the FF might be better for landscapes would be for high shutter speed handheld shots that would require the very wide apertures to avoid handshake/motion blur. For "serious" controlled landscape setups on a pod (you know, the type that people that are willing to put $10k+ into their setup tend to do), low iso, small aperture shots on the MF are going to beat the 35mm every time. Badly.
the biggest problem there is that you are making the assumption that both lenses will have the same resolution and the same field curvature characteristics, which is far from true.
anyone... post up your mf 35mm landscape shot, that was taken at f/2.8, and lets evaluate the field curvature characteristics, the vignetting, etc., against the pic i posted...
