04-07-2016, 09:35 AM   #46
normhead's Avatar
QuoteOriginally posted by SeattleDucks Quote
WOW!
And this is why I rarely get involved with photography gear forums, because there is always one or two folks who seem to relish being rude.
Take care all, I'm out.
Best,
Ross
Or maybe it's just you.
04-07-2016, 09:38 AM - 1 Like   #47
QuoteOriginally posted by osv Quote
oh? do you have any pics to back up that claim? i think not
Have a look through my many photos on the post your photos shoots and see my ratio of small apertures. The largest I go is f/8. My last batch were f/8 but only to keep the shutter speed up, as though I was with a tripod I was on a heavily used bridge that vibrates when people run or walk on it. Plus I didn't have need of close things being pin sharp.
Also go to M Salon in Vienna and you will see more than 20 photos of mine in an exhibition and the shots there will be nearly all f/11 to f/16.
I have absolutely nothing to prove to a pixel peeper as that is not what photography is about. It isn't about specs, but about something that you can't put on a resolotion chart...
The thing I see too much on gear forums are people shooting with an f/1.2 and with an orgasmic cry shout: "Look at this it is wide open". Big whoops. You see a photo where nothing is actually pin sharp and the device of wide open hasn't been used for an aesthetic purpose but for the purpose of online willy waving.
Not for me, thank you.
04-07-2016, 09:56 AM   #48
osv
QuoteOriginally posted by itshimitis Quote
with what camera? because f/11-f/16 on mf does not have the same dof/diffraction problems as f/11-f/16 on ff... that's not pixel peeping either it's something that every photographer should know.
your claim was that there are multiple reasons why a lens should be stopped down well into the diffraction range, and that remains unsubstantiated.
but i'm trying to keep an open mind the only reason that i can see for hitting f/16 on ff is because of a foreground object that's way too close to the lens... or maybe to darken the image, when you don't have an nd filter, but that's questionable.
04-07-2016, 10:33 AM   #49
Sony need to go so much further than the sensor. It can be the best sensor ever, but if it's in a "computer lens attachment device" rather than a really great to use camera . . .
04-07-2016, 10:38 AM   #50
fast glass doesn't have to be used wide open, that's a logical fallacy.
the priority is to get a lens that can take a landscape shot at a wider aperture: "Better image quality under larger aperture. IF a 35mm FF lens can be used at a larger aperture, everything you said will be canceled out."
modern fast glass has less vignetting and fewer aberrations all the way up thru f/5.6 at least, so it should always be evaluated for landscape shooting.
The point is that you are saying that full frame with high megapixels is better than medium format with fewer megapixels because faster glass is available for the full frame camera than for the medium format camera. But if you are shooting at f5.6 on full frame and f8 on medium format, then I really think using a f1.4 lens is probably wasted and going to give you a lot bigger piece of glass than you really need.
04-07-2016, 10:38 AM   #51
STOP HIJACKING THE THREAD. If you want to wonk out about this argument take it to PMs or start your own thread.
04-07-2016, 10:53 AM - 2 Likes   #52
mikeSF's Avatar
04-07-2016, 11:22 AM - 1 Like   #53
the priority is to get a lens that can take a landscape shot at a wider aperture: "[b]Better image quality under larger aperture. IF a 35mm FF lens can be used at a larger aperture, everything you said will be canceled out
Since when?
You'll find the odd chap who shoots landscapes wide open for some creative reason, but I would say that 99.9% of landscape users leave their camera on f/8-f/16 for dof and exposure time.
I don't know about you but one of the tricks to getting lovely colour in the sky late afternoon is to extend the exposure time, not shorten it. You could argue to then use NDs but why would you when the lens is performing best at f11 anyway.
All sounds odd to me.
04-07-2016, 11:29 AM   #54
osv
assuming that both lenses don't have problems like vignetting, field curvature, spherical aberrations, etc, i would agree... but asking for that with slow glass at wider apertures is far from certain.
anyway, that's not the scenario that people out here are posting.
"f/16-f/22" and "stop way down" is the overwhelming sentiment
---------- Post added 04-07-16 at 11:30 AM ----------
QuoteOriginally posted by 2351HD Quote
Since when?
You'll find the odd chap who shoots landscapes wide open for some creative reason.
no one in this thread has ever advocated shooting landscapes wide open.
---------- Post added 04-07-16 at 11:52 AM ----------
no ff lens performs better at f/11, unless something is wrong with it; if nothing else, you are already into the range of visible diffraction by f/11... here is a list of lenses and their best tested apertures:
"None of the lenses performed any better after f/5.6 (for the center) or f/8 for the corners. Most were clearly getting softer at f/11."
https://www.lensrentals.com/blog/2011/11/stop-it-down-just-a-bit/
mf will behave the same way, when the actual dof(not the aperture number on the lens) is the same as f/11 on ff.
04-07-2016, 12:28 PM   #55
At which viewing distance?
04-07-2016, 03:13 PM - 2 Likes   #56
OSV, you said it, you said the priority is to get a lens that can take a landscape shot at a wider aperture.....
Any lens will perform better at F11 if it gives you the DOF that you need. There's no point having a sharp lens at f5.6 if you don't have the required depth of field.
I just don't see the point of your whole entire pitch here in this thread.
04-07-2016, 04:16 PM - 1 Like   #57
I will use the largest aperture that will give me the depth of field I need. It's all about 'acceptable sharpness' and this plays a part in all focussing techniques be they hyperfocal or otherwise. Sometimes foreground elements will mean you need the very smallest of apertures to get acceptable sharpness across the whole image. This may involve diffraction but then you decide whether you notice diffraction or out of focus areas most at the viewing distance you intend to go for. For real printed images forget 100%. I don't think many would pick out diffraction on a 40 x 30 inch image stood the right distance away from it. More might pick out areas that are out of focus.
04-07-2016, 06:18 PM   #58
mikeSF's Avatar
agree, i would rather have some negligible diffraction than to have entire elements out of focus due to insufficient DOF.
04-07-2016, 06:31 PM   #59
clackers's Avatar
:LOL:
04-07-2016, 06:47 PM   #60
osv
optical bench tests are done at infinity, imatest needs to have the chart close enough to fill the frame, no guarantees how it'll look with radical changes in distance.
ultimately, i think that you have to test it how it'll be used, the landscape pics that posted are how i test lenses, at all apertures.
so i know that the m28/3.5 has minimal field curvature at 100+ yards, it has a flat focus field, minimal ca, and i know the apertures that it's usable at.
i've also tested a couple of dozen other 28mm legacy lenses, standing at that exact same spot, focusing at the exact same target; no lens has been able to match it.
you've seen the pic, it looks decent on the right side even at 100%, but at extreme distances, the right side goes soft, depending on how far it was focused into the scene... got to test it how it'll be used.
645d, 645z, aperture, camera, detail, dof, equivalent, f11, feet, ff, focus, frame, glass, landscapes, lens, lenses, love, medium format, print, prints, resolution, sensor, sony, source, switch
You soon-to-be K-1 owners are getting a Rolls Royce of a camera... BigMackCam Pentax DSLR Discussion 27 03-21-2016 08:43 PM
Tethering coming to a 645Z near you. GarethC7 Pentax Medium Format 41 10-21-2014 04:10 AM
Calling 645Z owners - testing dark frame behaviour Ed Hurst Pentax Medium Format 50 07-31-2014 05:28 PM
K3 vs Sony A7: which one will you buy for the same price? yusuf Pentax K-3 23 06-15-2014 07:46 AM
will you switch to SDHC cards? barondla Pentax DSLR Discussion 9 11-22-2006 04:14 PM
All times are GMT -7. The time now is 12:59 PM. | See also: NikonForums.com, part of our network of photo forums!
