04-13-2016, 10:48 AM   #1
bobbotron's Avatar
Hand holding the 645 portrait
I've been doing the single in april challenge with an original 645 and a 200mm lens. This is a pretty hearty combo. I can hand hold it reasonably well in landscape orientation, but portrait gets a bit wiggly. I'm right handed, my first instinct is to have my elbow way out to hold the grip well. This doesn't seem ideal, I was wondering if you folks had any suggestions for hand holding the 645. I think this is a lot easier with lighter primes. The 75mm is looking really good. (A travel tripod would be the best solution here... but I don't have the capital for one at the moment.)
04-13-2016, 11:04 AM   #2
monochrome's Avatar
Try it with your right hand under and your right elbow wedged against your hip bone or side. Support your lens on the left palm. I do that with larger dSLR's and long lenses.
04-13-2016, 11:11 AM   #3
Alex645's Avatar
I go both ways....usually like you, with right wing in the air, until I get too fatigued, and then switch down with my upper arm braced against my torso. The only down side to this method are flip-flopped contact sheets, so I try not to switch arm positions until I switch rolls.
04-13-2016, 11:43 AM   #4
bobbotron's Avatar
I tried something like that today, I'll give it another shot. Unfortunately, I'm afflicted with a minor but permanent palsy in my left hand/arm that's only accentuated during concentrating tasks like this, so a number of two handed shooting techniques are less accessible to me. On the other hand (ha), I have a very strong and steady right arm and am a big guy so I can handle larger gear, but it is tiring with this camera.
I tried shooting with the camera revered, triggering the shutter with my thumb. I think it could work out well if I had more practice at it.
04-13-2016, 11:44 AM   #5
With a physically longer lens cradling it in the crook of your left arm can help steady the camera in both portrait and landscape modes. Takes a little getting used to
Photographer Ron Reznick, although shown with FF DSLR I see no reason that it cannot work with the 645
http://www.trapagon.com/temp/PortraitHold.jpg
http://www.trapagon.com/temp/LandscapeHold.jpg
EDIT: only just seen your last post where you mention your left arm problems so no idea if this post of any help - just hope it may be
04-13-2016, 01:09 PM   #6
bobbotron's Avatar
QuoteOriginally posted by TonyW Quote
I'll definitely give it a shot, that looks like a useful pose, thanks!
04-13-2016, 05:21 PM   #7
I sympathize with you holding the 645z in portrait mode can be a bear. My solution was to use the handle from my LED panel and use it like a pistol grip. Holding the grip in my left hand and controlling the shutter with my right. Worked quite well and took 30+ business portraits last Friday using the 120mm Macro. What would be nice would be a pistol grip with a built in release so I could hold the grip in my right hand and steady the camera with the left.
Would be even better would be a faster sync speed
645d, 645z, camera, hand, medium format, portrait
An old 645 portrait bkpix Pentax Medium Format 5 10-05-2015 11:41 AM
Hand holding 645D? windhorse Pentax Medium Format 27 03-22-2015 12:54 AM
Holding the Q and Reducing LCD Glare CWRailman Pentax Q 14 11-10-2014 08:13 PM
Hand holding ND10 Filter? libbyh Photographic Technique 9 07-05-2012 11:49 PM
Breaking my hand-holding records with 0.3, 0.6, 0.8 and 1 sec shutter hinman Pentax DSLR Discussion 2 01-02-2008 10:56 PM
All times are GMT -7. The time now is 08:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
