04-14-2016, 08:40 PM   #1
Need help with Pentax 67
1. What's the aprox aperture value for 2.4, 4, 5.6, and 8 in 35mm?
2. How do you focus for portrait? I usually get un-focused images quite a lot. First I focused on the head and then re-compose to the body usually. Due to the viewfinder, it's quite hard to see clearly.
3. Any differences between newer and older version of 105mm f2.4?
4. I want to prevent scratching and I heard that there is some kind of special tapes for film camera. Do you know the name of it?
5. Will Pentax 67ii prism provide brighter viewfinder?
6. Where can I send my Pentax 67 for cleaning dust, repairing, and etc?
04-14-2016, 09:39 PM   #2
QuoteOriginally posted by rlatjsrud Quote
The same.
They all have the same optics, just different coatings (SMC on the later lenses) and a different cosmetic design for the latest version.
Eric can help you (pentaxs.com).
04-15-2016, 05:50 AM - 1 Like   #3
Duplo's Avatar
a few thoughts on the subject and hopefully helpful.
1. if you mean DOF equivalent f numbers when comparing 35mm and 67, using the diagonal as a reference, as they are different rectangular formats and assuming similar field of view,
Then for practical purposes the 105mm 67 lens at f2.4 will roughly equal a 50mm lens on 35mm format at f1.1, f4=f1.9, f5.6=f2.7, f8=f3.8. roughly a 2 stop difference.
It is quite useful to keep in mind if you come from 35mm or APS-C format and are not quite sure what to expect from a 67 camera.
2. takes a lot of practice, especially wide open. focus and recompose will be very likely to throw off focus. I shoot a 67ii and while I do see occasional misfocused images, then I have found it to be a practise thing. shooting it almost daily helps.
On the 67ii I tend to get precise focus using the micro prism and then the ground glass to correct for any misalignment or movement during when recomposing.
3. I have the latest model, but i think some changes to coatings and to the use of radioactive materials in the coatings on some of the older ones.
4. never heard of it
5. a definite yes. i find the 67ii a lot brighter and easier to focus.
6. I do not know any repair shops in the US, hopefully others will be able to help you out. Personally I use a local one in Copenhagen, Denmark.
04-15-2016, 01:43 PM   #4
3. The Super Takumar used Thorium glass and nearly all of the SMC Takumars did not. The Thorium was replaced by another high index glass (possibly Lanthanum). A different design but both types perform well.
4. There are a few people that use gaffers tape to cover the surfaces.
645d, 645z, camera, medium format, pentax, viewfinder
Need help with Pentax ME Super camerakid Pentax Film SLR Discussion 7 08-07-2016 12:17 AM
New to Pentax, need help deciding with lenses. dlopez6243 Pentax SLR Lens Discussion 16 10-10-2015 04:35 PM
Need some Tech Help with 67 500mm f5.6 Lens Orion12 Pentax Medium Format 11 05-27-2015 04:30 PM
NEED HELP WITH PENTAX -A 400mm lens neerod Pentax K-5 9 08-30-2014 05:36 AM
Need help choosing between 645N and 67!! artistcjconrad Pentax Medium Format 6 07-24-2009 09:30 AM
All times are GMT -7. The time now is 06:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
