04-17-2016, 08:04 AM   #1
Pentax 645: Priolite vs. leaf shutter lenses?
Hello folks, I hope you all enjoy your weekend. I have a question to Pentax 645d/z users who also use Priolite MBX500 and do outdoor portrait photography. I keep reading about the disadvantage of the Pentax 645 system for outdoor portraits due to a lack of modern leaf shutter lenses but doesn't Priolite (and hopefully Profoto too) kind of replace them? Thanks and please correct me if I'm missing something. Take care
04-17-2016, 08:33 AM   #2
bobbotron's Avatar
Either would work. The Pentax flash system has hss support as well. If you're doing fill flash you need neither.
04-17-2016, 11:31 AM   #3
I really wonder what's the advantage of using leaf lens while Priolite can support 1/4000? Many photographers didn't answer this question at all.
04-17-2016, 03:52 PM   #4
gavincato's Avatar
QuoteOriginally posted by rlatjsrud Quote
power. you lose power over your "official" flash sync speed once HSS is used.
04-17-2016, 03:56 PM   #5
bobbotron's Avatar
QuoteOriginally posted by gavincato Quote
I was going to say the same thing. One really needs to check the HSS guide numbers (which change as the shutter speed goes up!) and do some math to compare it to output from normal flashes plus a leaf shutter. It really depends what you want to do with your flash too...
04-17-2016, 05:53 PM   #6
clackers's Avatar
And aren't leaf shutters only rated for 20,000 or so actuations?
04-17-2016, 06:21 PM - 1 Like   #7
bobbotron's Avatar
Live dangerously. :P
04-17-2016, 06:38 PM   #8
clackers's Avatar
QuoteOriginally posted by bobbotron Quote
I was about to say 'expensively', but you MF guys use fiddies to light your cigars, apparently! ☺
04-17-2016, 06:40 PM   #9
First time hearing that. My Leica X Vario has a leaf shutter and I have at least 60K clicks on it. Plus some Leica S, Hassy, Phase lenses have leaf shutters of course and I doubt they only last 20K.
04-17-2016, 06:51 PM   #10
clackers's Avatar
QuoteOriginally posted by Irie Quote
This old Fuji was rated to 10,000, Irie, what do Leica say is the MTBF for your Vario?
Fuji GW 690 III Leaf-Shutter Lifespan - Photo.net Medium Format Forum
04-17-2016, 07:11 PM   #11
bobbotron's Avatar
That's actuations between servicing I believe.
---------- Post added 04-17-16 at 10:17 PM ----------
Haha - not me, only old manual focus medium format equipment for me. I think the most expensive lens I've purchased for the 645 was.. $200 USD? They are really fun to work with, and pretty great.
Regardless, I'd suggest looking at the amazing work the forum member LeRolls ( https://www.flickr.com/photos/chris_rankin ) does, with 1/180 of a second shutter speed, with a flash, outdoors (his exif is posted on his flickr). You don't need either HSS or a leaf shutter for incredible outdoor portraits, only for a subset of the field.
04-17-2016, 10:07 PM   #12
QuoteOriginally posted by kparseg Quote
Here is your answer Priolite MBX1000 HotSync - Initial Tests - Mark Kitaoka Photographs
04-17-2016, 10:15 PM   #13
I don't see any problems with 'power' at all. I need specific answer for this. Profoto B1 and B2 still have powerful light with HSS. I know that using HSS require more battery power and have to flash more but that doesn't mean leaf shutter lens have more advantage compare to HSS. I saw many professional photographers using HSS a lot.
04-18-2016, 02:09 AM - 1 Like   #14
Digitalis's Avatar
When it comes to working with flash: Power is always an issue, especially with HSS is being used and if you don't see that and understand the compromises involved, you are going to make some pretty expensive mistakes. It is important to factor in the lighting modifiers in use here, bare bulb HSS will lose about 1/2 the normal GN of the flash* - add a 120"X120" double scrimmed softbox and that will cut that amount of light in half on top of the losses incurred from using HSS.
Sometimes you're better off using sticking to the standard sync speeds and use the flash at 1:1 power, with a large light modifier getting the subject in focus and lit properly...rather than using HSS flash with a small modifier and unnecessary and inappropriately shallow DOF caused by using too wide an aperture and all the compromises in IQ caused by using lenses wide open.
And everyone simply must jump on that burgeoning bandwagon. Shallow DOF portraiture with the ambient sunlight being underexposed isn't inherently a good technique - it is how it is used and more often than not it is an overused technique for people who are aesthetically stunted, and have no idea what it really takes to create a good portrait that actually says something about the subject.
I suspect the tiny leaf shutter only is in use at shutter speeds under 1/500th - anything over that and longer than 1s would be purely electronic in order to enhance the longevity of the shutter mechanism. One of the first indications of a Leaf shutter approaching failure is the long exposure times are longer than what is indicated.
Leaf shutter units can last longer than 20,000 actuations - they don't exactly disintegrate into a puff of smoke after 20,001 firings but when you go substantially over the recommended number of actuatons**, there is an increasing chance things will go pear shaped: mechanical issues and problems such as mis-firing, uneven and inaccurate exposure and inability of the lens to automatically re-cock itself after firing are common failure modes and are signs the shutter requires servicing ASAP. If you keep using the shutter past the recommended MBTF, there is an escalating chance you will damage something really expensive.
* I'm being generous here, depending on the shutter speeds and a number of factors you can lose substantially more light than this.
**I'd say anywhere approaching 40,000 firings and over. The figure of 20,000 firings is a commonly accepted service threshold for Seiko and Copal leaf shutters.
04-18-2016, 04:40 AM   #15
What is a fiddie?
645d, 645z, camera, leaf, leica, medium format, pentax, priolite, shutter
Pentax 645z and leaf shutter lenses - any success? salpardido Pentax Medium Format 31 09-11-2017 05:28 PM
New Pentax leaf shutter 645 medium format lenses coming soon i83N Pentax News and Rumors 73 10-03-2014 08:03 AM
For Sale - Sold: Pentax 645 Leaf Shutter 75mm 2.8, 645-A 150mm F3.5 MightyMike Sold Items 13 04-03-2012 06:47 AM
Any experience on Pentax 645 135mm f/4.0 LS -- Leaf Shutter hinman Pentax Medium Format 11 11-23-2010 05:15 PM
All times are GMT -7. The time now is 06:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
