05-01-2016, 01:30 AM   #1
Micro Contrast and Corner Sharpness difference between 645 35mm A 3.5 MF and HD
Hi,
Does anyone here had the chance to compare the Micro Contrast and Corner Sharpness between the old 645 35mm A 3.5 MF and new HD PENTAX-D HD FA 645 35mm F3,5 AL [IF] ?
I actually don't need Autofokus and the MF version of this lens is very affordable.
Thank you in advance for your help!
05-01-2016, 02:02 AM   #2
Sample files here for each lens: https://www.pentaxforums.com/forums/48-pentax-medium-format/312720-testing-35mm-options-4.html
You can do your own comparison.
05-01-2016, 04:10 AM   #3
Joa
Thanks a lot!
Do you know what focal you get if you adapt the Pentax 645 35mm FA to a Canon Full Frame Body?
---------- Post added 05-01-16 at 04:17 AM ----------
sorry, I meant focal lenght.
05-01-2016, 04:37 AM   #4
oh dear, with this question you open the pandoras box on this forum...
the noted focal length on lenses always(?) refers to the focal length a full frame body would make use of[*]. In your case that would simply mean the 35mm will stay a 35mm on a full frame body[*].
However the 35mm on a medium format camera would exercise a much wider field of view, which would equal a fraction of the focal length on a full frame body. I believe the ratio for focal length conversion from full frame body to a medium format is about .75 if i am not mistaken. but i am sure somebody can help out
[*] with its respective field of view
cheers,
05-01-2016, 05:08 AM   #5
Na Horuk's Avatar
QuoteOriginally posted by Joa Quote
The lens is 35mm, so if you put it on a certain camera, it will look like all other 35mm lenses will look on that camera. However, the field of view will be different depending on the camera - 35mm on 645 camera is really wide angle; on FF it is medium wide; on APSC it is normal.
You can easily adapt from a bigger format down, but not necessarily the other way around, just because the smaller format lenses have a smaller image circle, so you would end up with dark corners on a larger format camera.
That said, adapting 645 lenses to other formats can have its problems. For example, lack of automation, loss of contrast (because so much light is bouncing around inside of the camera), and so on. Usually medium format lenses get adapted to APSC or FF format with tilt/shift adapters. Otherwise, it generally makes more sense to buy a smaller lens that is made, optimized, for the format that you want to use it on
05-01-2016, 05:33 AM   #6
Joa
Yes, thank you, I was aware of that, my intention is to use it as a tilt/shift, just wasn't sure how wide it would be on my Canon 5D MKII.
05-01-2016, 02:05 PM   #7
You'd get 54.4 degrees horizontally and 37.8 degrees vertically......exactly the same as a 35mm lens from Canon or Zeiss.
Bob
05-01-2016, 04:20 PM   #8
Ymy intention is to use it as a tilt/shift..
What adapter will you use?
05-01-2016, 10:40 PM   #9
Joa
Really?
I always thought it should be wider? Why does a 35mm lens on APSC built for APSC cover a more narrow field of view on APSC than a 35mm lens built for full frame on full frame? Wouldn't a 35mm medium format also cover a wider field of view on full frame than a 35mm full frame lens on full frame?
---------- Post added 05-01-16 at 11:10 PM ----------
Really?
I was planning on using a kenko shift adapter. Thought that might have an effect on the field of view like a 21mm ring.
Kipon shift Pentax 645 P645 mount lens to Canon EOS EF adapter 5D II III 6D 700D | eBay
05-02-2016, 02:47 AM   #10
Really?
Well, for use as a T/S it's the image circle that's key. You ought to have plenty with this lens, as it was designed for (oh, boy, here we go....) FF 645. How it looks in terms of FOV is another matter---there's a handy table on this website you can find here
05-02-2016, 05:58 AM   #11
Joa
Thanks everyone, but it seems there are a lot of different views regarding this issue I was hoping to get a 21mm tilt shift for my Canon since the Canon 24mm TSE II is too narrow for my needs and the 17mm to wide. Would have loved to get something in between those two for a bargain price.
24x36mm, 35mm, 645d, 645z, adapter, apsc, camera, contrast, contrast and corner, corner, field, format, frame, full-frame, hd, lens, medium, medium format, mf, pentax, pentax 645 35mm, sharpness, shift, view
Difference between 645 FA and DFA lenses? prohtex Pentax Medium Format 12 09-27-2015 01:39 AM
Difference Between 21mm HD and DA Non HD rollsman4 Pentax SLR Lens Discussion 21 05-15-2015 05:12 PM
A difference between K-5 and K-3 retention of aperture or shutter speed settings at p MNCurt-K10D Pentax DSLR Discussion 10 04-21-2015 03:08 PM
What's the difference between Unsharp mask and sharpness & blur? Dewman Digital Processing, Software, and Printing 4 07-27-2014 06:13 AM
How much of a difference between 2.8 and 3.5 epqwerty Pentax SLR Lens Discussion 16 04-21-2010 01:00 AM
All times are GMT -7. The time now is 02:13 PM. | See also: NikonForums.com, part of our network of photo forums!
