07-09-2016, 03:06 PM   #1
Exposure simulation and Live View 645Z
When shooting with external flash and Live View in the studio it is not in any way helpful for the camera to simulate the exposure as it would be without flash (f8 and 1/125th reads as almost black of course). Has anyone come across a way to turn exposure simulation off??
Thanks in advance
07-09-2016, 03:17 PM   #2
QuoteOriginally posted by Ricgal Quote
Thanks in advance
Simulation only takes place in M mode, but there's no way to disable it.
The only workaround (which is sort of a hack) is to put the camera in TAv mode and select a very narrow auto ISO range, such as 100 to 125. This should give you a well-lit live view image at all times.
07-10-2016, 12:45 AM   #3
Kolor-Pikker's Avatar
I have the camera in a custom mode that works like "X" on the dial, and it does adjust live view automatically, although it still tends to be on the dark side unless I select spot meter and move the focus point to a dark area on the subject.
The two problems are that there is no way to select exposure sim or auto brightness manually like you can on a Canon camera, and there is a limit to how much the preview exposure can deviate from the meter, which is totally baffling to me. On my old 5D2 there can be a 10EV difference between your set exposure and the preview so long as you scroll the EV comp far enough, but on the Z it won't let you brighten/darken the image past the meter's range - which is often not enough.
07-11-2016, 01:41 AM   #4
Thanks guys
And it would be soooo easy for them to sort it
645d, 645z, camera, exposure, exposure simulation, flash, medium format, simulation, view
Live View Exposure Simulation pentaphil Pentax DSLR Discussion 3 01-26-2016 01:21 AM
K-S2 Live View Exposure Simulation/Preview anu l Pentax K-S1 & K-S2 7 12-08-2015 12:52 PM
Live View and Multi Exposure Tjompen1968 Pentax K-3 13 12-27-2014 12:24 PM
645Z and Live View MrPhil Pentax Medium Format 6 09-11-2014 12:32 AM
645Z - DOF Preview in Live View? Ryan Tischer Pentax Medium Format 6 07-31-2014 04:17 PM
All times are GMT -7. The time now is 09:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
